1971 914-4 Frankenstein, w/ 912E 2.0 L-Jet FI? |
mikesjunk |
Dec 20 2015, 05:39 PM
Member Group: Members Posts: 71 Joined: 29-November 15 From: goddard, KS Member No.: 19,423 Region Association: None |
Ok so I'm working on a 1971 914-4 which from another thread it appears to have a 75-76 2.0 912E L-Jet FI system on it from the PO.
I have plumbed new fuel lines through out the car, cleaned fuel tank and it has fresh gas. I went through the dual relay and redid it all which I did find one wire on the wrong terminal from the diagram I had. The previous symptom was that it would start and then die when the key was released. So I threw a battery in it and yep that's what it does. It will fire and run momentarily then die. First issue is that I don't hear the fuel pump run. It's currently wired from the original harness with some PO adds ons like a fuse. It is not wired to the dual relay but back into the harness that runs to the relay box. I put a meter on it while testing and didn't ever see any voltage. So to make sure this wasn't the issue I hot wired it to run off the battery while I tested that. But that didn't fix the main issue. Next item is that the ignition switch looks like it's from the movies and has been hot wires. Of course they did it through and around the knee pad so I'm digging into that now. I unwired it so I could remove the knee pad. From the ignition switch area there looks like 4 wires. red, red/black stripe, a black and a gray. The gray one wasn't hooked to anything. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.mikesjunk.com-19423-1450654793.1.jpg) From the harness there were 5 wires. The Black/Yellow and Blue/Yellow weren't hooked to anything. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.mikesjunk.com-19423-1450654793.2.jpg) I'll start researching the wiring diagrams but anyone want to post a response to short cut this would be appreciated. Also the key/cylinder feels pretty bad so anyone recommend someone who can go through it? I saw a guy on ebay listing this but looking for recommendations as it will need something eventually. |
rick 918-S |
Dec 20 2015, 06:47 PM
Hey nice rack! -Celette Group: Members Posts: 20,512 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
If it cranks and fires with the key that's good. The wiring may be a mess but at least some of it is connected correctly. Check power to the coil with the key on. If that is good. Check to see the fuel lines are connected correctly. The pressure regulator should be last in the fuel flow direction. (after the injectors) This will cause the exact symptom you described.
Lo-Fi Version | Time is now: 26th June 2024 - 03:00 AM |
