> Think I;m going to give this a shot
StratPlayer
post Dec 21 2015, 12:44 PM
StratPlayer
For all of you with D-Jet setup, I'm going to purchase this and see what difference it makes, hoping install will not be a problem.
123\PORSCHE-4-R-V-IE http://www.leenapk.nl/123porsche4RVIE.html?language_code=en
luskesq
post Dec 21 2015, 01:48 PM
It will likely fit but are you sure it has trigger points? I didn't notice that in the description. Kinda necessary for the stock D-jet.
Keith
JamesM
post Dec 21 2015, 06:28 PM
QUOTE(luskesq @ Dec 21 2015, 12:48 PM) *
Keith
I was wondering the same thing so I looked through the install instructions
http://www.123ignition.nl/downloads/manuals/123PORSCHE4.pdf
There are two extra wires "yellow" and "White" that get attached to pins 1 and 3 on the "Bosch connector" on d-jet models, so it looks very likely that they made an electronic replacement for the injection points. If this is what it looks to be then this is beyond awesome given the injection points are the one thing we haven't had a source for.
Its digital and has adjustable timing curve to boot. This is seriously exciting.
JeffBowlsby
post Dec 21 2015, 07:58 PM
914 Wiring Harnesses
QUOTE(JamesM @ Dec 21 2015, 04:28 PM) *
Except the trigger points require 3 wires - a common and 2 poles. Not sure how this works with only two trigger point wires, and then a disconnect connector to the harness is needed.
JamesM
post Dec 22 2015, 11:48 PM
QUOTE(Jeff Bowlsby @ Dec 21 2015, 06:58 PM) *
Its been a while since I dissected d-jet, but the common is most likely +voltage which this distributor already has a source for. I dont actually know that it is what they are doing here, but i could see it working.
StratPlayer   Think I;m going to give this a shot   Dec 21 2015, 12:44 PM
scotty b   :confused: http://www.123ignition.nl/id/60.html   Dec 21 2015, 12:46 PM
StratPlayer   For the D-Jet setup is has to be the R-V-IE distri...   Dec 21 2015, 12:49 PM
thieuster   The seller is a Dutch company and has been around ...   Dec 21 2015, 01:25 PM
luskesq   It will likely fit but are you sure it has trigger...   Dec 21 2015, 01:48 PM
thieuster   It will likely fit but are you sure it has trigge...   Dec 21 2015, 02:46 PM
r_towle   It will likely fit but are you sure it has trigg...   Dec 21 2015, 04:09 PM
Millerwelds   I previously posted this in another forum. It does...   Dec 21 2015, 06:34 PM
JamesM   It will likely fit but are you sure it has trigge...   Dec 21 2015, 06:28 PM
Jeff Bowlsby   There are two extra wires "yellow" and ...   Dec 21 2015, 07:58 PM
JamesM   There are two extra wires "yellow" and...   Dec 22 2015, 11:48 PM
nordfisch   [quote name='Jeff Bowlsby' post='2280018' date='D...   Dec 26 2015, 02:55 PM
StratPlayer   http://www.ebay.com/itm/Porsche-356-912-91...w-/16...   Dec 21 2015, 07:32 PM
Mueller   Electronic triggering of the injectors has been do...   Dec 21 2015, 08:19 PM
Old Yella   Precious, I wants one. Now they just need to do a...   Dec 21 2015, 09:04 PM
Philip W.   This is very cool, can't wait to hear back abo...   Dec 21 2015, 11:09 PM
thieuster   First thing this morning, I contacted the owner of...   Dec 22 2015, 02:36 AM
Jacob   They have US distributors: http://www.123ignition....   Dec 22 2015, 06:49 AM
thieuster   Given the current Dollar vs Euro exchange rate, it...   Dec 22 2015, 09:40 AM
StratPlayer   You must take care of fitting the contacts to the ...   Dec 26 2015, 09:13 PM
Philip W.   Did you order one yet?   Dec 27 2015, 10:32 PM
StratPlayer   No not yet...   Dec 28 2015, 12:53 PM
StratPlayer   It's on its way, order right from the company ...   Jun 10 2016, 02:20 PM
Millerwelds   Sweet. Super anxious to hear how you like it. I ...   Jun 10 2016, 02:31 PM
mgp4591   Sweet. Super anxious to hear how you like it. I...   Jul 7 2016, 03:12 PM
jim_hoyland   :) Very cool, let us know how it works out for yo...   Jun 10 2016, 03:06 PM
StratPlayer   It's being installed today, pics and a write u...   Jul 7 2016, 03:06 PM
StratPlayer   I just picked up my car with the new 123 distribut...   Jul 8 2016, 04:15 PM
Millerwelds   Thanks for the feedback! :beer2:   Jul 8 2016, 04:18 PM
StratPlayer   The install is easy, we set the curve setting at 4...   Jul 8 2016, 04:20 PM
Millerwelds   The install is easy, we set the curve setting at ...   Jul 8 2016, 04:39 PM
DavidSweden   The install is easy, we set the curve setting at ...   Jul 9 2016, 01:38 AM
JOEPROPER   I'm anxious to see the pics and write up on th...   Jul 8 2016, 04:43 PM
rhodyguy   Does this distributor require a vacuum signal?   Jul 8 2016, 05:56 PM
StratPlayer   There is a vacuum port on the distributor..   Jul 8 2016, 10:44 PM
siverson   Anyone know if this distributor can be used on a s...   Jul 8 2016, 11:09 PM
Mueller   The tuneable setup they have is pretty cool, too b...   Jul 8 2016, 11:12 PM
StratPlayer   In the install instructions there is a list of diz...   Jul 9 2016, 09:03 AM
rhodyguy   as they seem to offer units for 356s and 912s, i w...   Jul 9 2016, 10:46 AM
Mueller   as they seem to offer units for 356s and 912s, i ...   Jul 9 2016, 12:38 PM
StratPlayer   as they seem to offer units for 356s and 912s, i ...   Jul 10 2016, 05:55 PM
Mueller   I wish I wasn't a lazy American and I knew Ger...   Jul 10 2016, 06:35 PM
lonewolfe   I wish I wasn't a lazy American and I knew Ge...   Mar 3 2017, 05:37 AM
- Lo-Fi Version Time is now: 6th January 2025 - 06:07 PM
