> Project 914 1.8T, Some pics of the conversion...
914_1.8t
post Sep 25 2004, 07:14 PM
I've enjoyed seeing pics of everyones cars and buildups. Few people wanted me to post some pics of the work in progress and I finally found my digital camera, so here are a few pics:
lapuwali
post Sep 27 2004, 02:26 PM
Not another one!
It's not uncommon to make up axles by just taking the four axles from the donor and target, cutting, and welding the ends together to make two complete axles and four extra pieces. Seen it done on several swaps. It's not difficult to alter length this way, either, to accomodate transaxles that put their output flanges in a different place.
Most fwd cars use transverse mounted engines, with the crank perpendicular to the centerline of the car. Thus, they also have to have transaxles where all of the shafts run parallel to each other. Audi and Subaru primarily use longitudinal layouts, with the crank and main gearbox shafts running parallel to the car's centerline, and thus have to turn the power 90d at the diff. There are also some VWs done this way, thanks to parts sharing w/ Audi. Many of the Brazilian-made VWs use the longitudinal layout, too, like the Fox.
I wonder:
- how hard would it be to adapt a T4 or a Six to an Audi gearbox?
- how much heavier is the Audi gearbox?
- how much are the replacement parts?
An Audi transaxle swap might be more cost-effective than rebuilding a 901, esp. if the internals are cheaper, to boot. Depends on how much the gearboxes cost used, and how much it would cost to fabricate axles. Since a full rebuild of a 901 is over $4K and even a quality refurbishment is going to run close to a grand, the Audi bits would have to be awfully expensive to not make this a more viable way to go.
914_1.8t   Project 914 1.8T   Sep 25 2004, 07:14 PM
914_1.8t   Above was a pic from the back showing the sub-fram...   Sep 25 2004, 07:16 PM
914_1.8t   Pic of ground/engine clearance from under car:   Sep 25 2004, 07:17 PM
914_1.8t   Pic from below of turbo almost hitting battery tra...   Sep 25 2004, 07:18 PM
914_1.8t   Seat that I will be using (from late model RX7) an...   Sep 25 2004, 07:19 PM
914_1.8t   I pushed the fender out sightly (about 2"), when t...   Sep 25 2004, 07:22 PM
914_1.8t   So, i've managed to get the motor started but ...   Sep 25 2004, 07:26 PM
Hi_Fi_Guy   Very cool project. Besides all the obvius stuff we...   Sep 25 2004, 07:55 PM
bob91403   Seat looks good. Does it give enough room for the ...   Sep 25 2004, 08:10 PM
scott thacher   quik ? which tranny are you using and how do you...   Sep 26 2004, 01:44 AM
914_1.8t
  Sep 27 2004, 01:27 PM
914_1.8t   <...   Sep 27 2004, 01:53 PM
Mueller
  Sep 27 2004, 02:08 PM
Cloudbuster   As for halfshafts, I'm quite sure you can get ...   Sep 27 2004, 02:12 PM
freezing14   hey mike,, I went to the link read the whole thi...   Sep 27 2004, 02:25 PM
lapuwali   It's not uncommon to make up axles by just tak...   Sep 27 2004, 02:26 PM
freezing14   I have no reference for this but i would think tha...   Sep 27 2004, 02:29 PM
914_1.8t   <...   Sep 27 2004, 03:39 PM
Aaron Cox   is this a 6 speed? mate this trans to a type 4 o...   Sep 27 2004, 04:04 PM
75boxster   SKS on Audiworld.com did this conversion a couple ...   Sep 27 2004, 11:31 PM
Mueller
  Sep 27 2004, 11:48 PM
75boxster   You are probably right about the SKS car. I have ...   Sep 28 2004, 09:14 AM
914_1.8t   <...   Sep 28 2004, 09:37 AM
neo914-6
  Sep 28 2004, 03:44 PM
Mueller   Felix, I couldn't find the axle adapters on t...   Sep 28 2004, 04:19 PM
neo914-6   Mike, Here a pic: RH axle adapter Felix   Sep 28 2004, 04:28 PM
Mueller   thanks Felix........I'd say those are steel, I...   Sep 28 2004, 04:43 PM
andys   Try these guys for the axles; I think they do spec...   Sep 28 2004, 05:38 PM
neo914-6
  Sep 28 2004, 11:53 PM
Andyrew   Looks like it started from a 914... Counts as a 91...   Sep 29 2004, 12:20 AM
Mueller   well....i stand corrected, it is/was a 914 :)   Sep 29 2004, 12:44 AM
914_1.8t   <...   Sep 29 2004, 12:41 PM
Mueller   Fremont Steel off of Fremont Blvd, in Fremont :), ...   Sep 29 2004, 01:38 PM
914_1.8t   Thanks, i'll stop by and talk to them about th...   Sep 29 2004, 02:06 PM
Mueller
  Sep 29 2004, 02:45 PM
fiid   Bayshore Metals in San Francisco can help you with...   Sep 29 2004, 03:13 PM
914_1.8t   Update... Before I could get the enfine to fire u...   Oct 6 2004, 07:03 PM
914_1.8t   Radiator with some misc radiator hoses I found at ...   Oct 6 2004, 07:07 PM
914_1.8t   Pic of the car: Still need to work on those 1/4 pa...   Oct 6 2004, 07:08 PM
914_1.8t   oops...lets try again: I think i will need adjusta...   Oct 6 2004, 07:10 PM
914_1.8t   One more from the side... Paint looks pretty crapp...   Oct 6 2004, 07:12 PM
neo914-6   Good job getting it running! :trophy: I'l...   Oct 7 2004, 12:49 AM
neo914-6   "Sonu" (sorry for the misspelling), It was good t...   Oct 11 2004, 12:31 AM
neo914-6   I just realized I may have 911 axles when I purcha...   Oct 11 2004, 12:48 AM
James Adams   Check out these axles. Many different lengths (15...   Oct 11 2004, 06:05 AM
914_1.8t
  Oct 12 2004, 12:44 AM
neo914-6   The axle overall length is 23 1/2" The outer CV fa...   Oct 12 2004, 12:57 AM
neo914-6   Axle end..   Oct 12 2004, 01:01 AM
neo914-6   CV end...   Oct 12 2004, 01:02 AM
fiid   What does the audi gearbox output shaft flange loo...   Oct 12 2004, 10:31 AM
914_1.8t     Oct 12 2004, 01:41 PM
914_1.8t   ...   Oct 13 2004, 11:21 AM
914_1.8t     Oct 13 2004, 12:11 PM
fiid   This looks totally do-able. The 911 driveshafts a...   Oct 13 2004, 12:50 PM
914_1.8t     Oct 13 2004, 12:57 PM
914_1.8t   Audi Trans:   Oct 13 2004, 12:57 PM
914_1.8t   Boster trans:   Oct 13 2004, 12:58 PM
914_1.8t   Another of boxster trans:   Oct 13 2004, 01:31 PM
914_1.8t   try again: By the way, does anyone have a pic of ...   Oct 13 2004, 01:32 PM
fiid   A quattro tranny would work if you freeze (weld?) ...   Oct 13 2004, 01:37 PM
andys   ...   Oct 13 2004, 02:09 PM
neo914-6   Sonu, Your Audi output flanges must be 108mm to f...   Jun 4 2005, 01:10 PM
- Lo-Fi Version Time is now: 29th April 2025 - 06:21 PM
