Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
So, I was given a lathe that had electrical problems.
I sorted those problems, and I am now looking for some simple projects so I can learn the machine. My first thought is to turn some clutch pulleys out of brass. Do you have other suggestions? Attached thumbnail(s) ![]() |
r_towle |
Practice projects to get a feel for it.
Learn how to be precise and how much you can cut. It's easy to start with store bought bushings from the hardware store and cut them from there, for instance the side shifter rear bushing...that is store bought, then turned to fit the exact need. It wastes less material also. |
Series9 |
Practice projects to get a feel for it. Learn how to be precise and how much you can cut. It's easy to start with store bought bushings from the hardware store and cut them from there, for instance the side shifter rear bushing...that is store bought, then turned to fit the exact need. It wastes less material also. Good advice. Those plastic rear shift bushings all fit like shit. I'm definitely doing some of those in brass. |
Lo-Fi Version | Time is now: 24th June 2024 - 06:33 AM |
