mikesjunk |
Member ![]() ![]() Group: Members Posts: 71 Joined: 29-November 15 From: goddard, KS Member No.: 19,423 Region Association: None ![]() |
Ok so I'm working on a 1971 914-4 which from another thread it appears to have a 75-76 2.0 912E L-Jet FI system on it from the PO.
I have plumbed new fuel lines through out the car, cleaned fuel tank and it has fresh gas. I went through the dual relay and redid it all which I did find one wire on the wrong terminal from the diagram I had. The previous symptom was that it would start and then die when the key was released. So I threw a battery in it and yep that's what it does. It will fire and run momentarily then die. First issue is that I don't hear the fuel pump run. It's currently wired from the original harness with some PO adds ons like a fuse. It is not wired to the dual relay but back into the harness that runs to the relay box. I put a meter on it while testing and didn't ever see any voltage. So to make sure this wasn't the issue I hot wired it to run off the battery while I tested that. But that didn't fix the main issue. Next item is that the ignition switch looks like it's from the movies and has been hot wires. Of course they did it through and around the knee pad so I'm digging into that now. I unwired it so I could remove the knee pad. From the ignition switch area there looks like 4 wires. red, red/black stripe, a black and a gray. The gray one wasn't hooked to anything. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.mikesjunk.com-19423-1450654793.1.jpg) From the harness there were 5 wires. The Black/Yellow and Blue/Yellow weren't hooked to anything. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.mikesjunk.com-19423-1450654793.2.jpg) I'll start researching the wiring diagrams but anyone want to post a response to short cut this would be appreciated. Also the key/cylinder feels pretty bad so anyone recommend someone who can go through it? I saw a guy on ebay listing this but looking for recommendations as it will need something eventually. |
mikesjunk |
I'm cheap so my shop is at 45F and I have good coveralls. (IMG:style_emoticons/default/smile.gif) It's been in the high 20s to low 30s around here. I thought I saw somewhere the reading was supposed to be 7k at 16F. Today the reading was 3.7k and I put a heat gun down blowing on the cylinder head sensor. It dropped to 2.88k in about 30-45 seconds.
I put the screw fuel regulator in the line by itself and it holds 35psi at all times. No needle movement at all. On the relay at key on I'm getting 12v from the coil to 86c but 0V at both 88b and 88a so looks like this side is not working now. This is strange since when I was pinning out the harness in chart above I was getting 12 volts at 10 at all times. Hmmm. So I got an alligator clip, pulled the wires from the relay for both 88b and 88a and clipped them to the battery. Added the fuel pump to the battery and tried. Same thing starts and then dies. Maybe my imagination but may have rotated a few more times prior to dying. I did have a meter on the alligator clip and it would drop to 11.8ish during cranking. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:08 AM |
