1971 914-4 Frankenstein, w/ 912E 2.0 L-Jet FI? |
mikesjunk |
Dec 20 2015, 05:39 PM
Member Group: Members Posts: 71 Joined: 29-November 15 From: goddard, KS Member No.: 19,423 Region Association: None |
Ok so I'm working on a 1971 914-4 which from another thread it appears to have a 75-76 2.0 912E L-Jet FI system on it from the PO.
I have plumbed new fuel lines through out the car, cleaned fuel tank and it has fresh gas. I went through the dual relay and redid it all which I did find one wire on the wrong terminal from the diagram I had. The previous symptom was that it would start and then die when the key was released. So I threw a battery in it and yep that's what it does. It will fire and run momentarily then die. First issue is that I don't hear the fuel pump run. It's currently wired from the original harness with some PO adds ons like a fuse. It is not wired to the dual relay but back into the harness that runs to the relay box. I put a meter on it while testing and didn't ever see any voltage. So to make sure this wasn't the issue I hot wired it to run off the battery while I tested that. But that didn't fix the main issue. Next item is that the ignition switch looks like it's from the movies and has been hot wires. Of course they did it through and around the knee pad so I'm digging into that now. I unwired it so I could remove the knee pad. From the ignition switch area there looks like 4 wires. red, red/black stripe, a black and a gray. The gray one wasn't hooked to anything. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.mikesjunk.com-19423-1450654793.1.jpg) From the harness there were 5 wires. The Black/Yellow and Blue/Yellow weren't hooked to anything. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.mikesjunk.com-19423-1450654793.2.jpg) I'll start researching the wiring diagrams but anyone want to post a response to short cut this would be appreciated. Also the key/cylinder feels pretty bad so anyone recommend someone who can go through it? I saw a guy on ebay listing this but looking for recommendations as it will need something eventually. |
timothy_nd28 |
Jan 3 2016, 09:05 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I don't think they introduced cylinder head vents for the 1.7s till 73, so you might be okay. I'm also on the fence to either admire your setup as genius or rather a bunch of spare parts cobbled together.
The problem you have could be as simple as replacing the points in your distributor or the more expensive route of replacing the ECU. I'm not sure what's turning on the fuel pump with your setup, or why you have 2 fuel regulators in series. We bypassed the dual relay to rule that out, and you discovered a faulty fuel injector that's rated for a 1.6l bug. Could we get this running again, I like to think so but you will still have a crazy setup. I would hate to see you throw money at this. I love the Ljet, but it may be worthwhile returning this 914 back to a Djet once again |
Lo-Fi Version | Time is now: 26th June 2024 - 02:48 AM |
