Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,595 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
I've been trying to solve an issue that makes the driving rather unpleasant (IMG:style_emoticons/default/headbang.gif)
I have a 2056 D-Jet that I daily drive. Recently I replaced the fuel filter and since then, the car has developed this behavior which I don't see why it would be related. When I put in first gear and get going, the car doesn't pick up and is bucking. As I progressively press on the pedal, it suddenly picks up and gets going normally. While it's trying to get going, I've noticed that my A/F gauge tends to go lean and out of range. Things that came to my mind: faulty throttle switch which influences the fuel delivery, hence lean. On the TPS, I checked the open/close circuit of the 2 traces with the 10 switches and everything is good. Idle switch kicks in also. I checked the resistance of the whole D-Jet harness on the 25 pin connector at the CPU as suggested by Anders and everything is within range. Replaced the points and adjusted Dwell. Fuel pressure is set at 29psi (analog gauge inline). I swapped the TPS, the CPU, the MPS, the coil without any improvement. I'm running out of ideas... (IMG:style_emoticons/default/sad.gif) Maybe someone has experienced something like this (IMG:style_emoticons/default/confused24.gif) |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Check your motor mounts. If they both break it'll do exactly this. Timing could just be a coincidence.
QUOTE I turned out to be the CHT ground. McMark...Mark now Mid Western transplant made a custom CHT ( not sure where he got the thermister) with a separate ground. I installed it and it has been performing well since, about a year or two ago. Glad to hear it's working well. I should make some more now that it's proven. Where'd I put that thermistor part number... (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 18th June 2024 - 07:24 AM |
