74 2.0 Idle/Stall remedy suggestions appreciated, Ran fine one day, not so fine the next |
Jon Dugan |
Jan 3 2016, 02:17 AM
Newbie Group: Members Posts: 13 Joined: 3-January 16 From: Bay Area Member No.: 19,521 Region Association: Northern California |
Hello fellow 914ers,
First post here... My 74 2.0 was my daily driver for the past 5 years until it decided not to be... Ran fine one night, parked it, next morning no so much. Starts right up no problem but rev above say 2000 RPM, it wants to bog out and stall. I do get an occasional smooth rev through to red line though. Tried advance/retard adj with the dist and can now only find idle around 1600 RPM (normal idle was about 600 RPM I think) but then lose it whwn I try to dial it back down. Dist checks out fine ($65 test by Porsche mech in Campbell). The guys at PH suggest maybe the fuel pressure sensor (grenade) has failed. I have limited troubleshooting skills and budget and was hoping to get back into AX this year after a long hiatus so any suggestions will be much appreciated. Thanks in advance !! |
JeffBowlsby |
Jan 9 2016, 10:53 AM
914 Wiring Harnesses Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Assuming your car is a stock 1.8L L-Jet, fuel pressure should be 32-38 psi. 40psi is too high.
This manual may be helpful to you: http://bowlsby.net/914/Classic/zTN_Man12.pdf |
Jason74914 |
Jan 9 2016, 05:08 PM
Member Group: Members Posts: 76 Joined: 9-January 16 From: Dallas Member No.: 19,544 Region Association: None |
Assuming your car is a stock 1.8L L-Jet, fuel pressure should be 32-38 psi. 40psi is too high. This manual may be helpful to you: http://bowlsby.net/914/Classic/zTN_Man12.pdf Sorry, yes L-Jet (typo). I will re-check, but thanks for the link! |
Lo-Fi Version | Time is now: 25th June 2024 - 11:29 PM |
