Jon Dugan |
Newbie ![]() Group: Members Posts: 13 Joined: 3-January 16 From: Bay Area Member No.: 19,521 Region Association: Northern California ![]() |
Hello fellow 914ers,
First post here... My 74 2.0 was my daily driver for the past 5 years until it decided not to be... Ran fine one night, parked it, next morning no so much. Starts right up no problem but rev above say 2000 RPM, it wants to bog out and stall. I do get an occasional smooth rev through to red line though. Tried advance/retard adj with the dist and can now only find idle around 1600 RPM (normal idle was about 600 RPM I think) but then lose it whwn I try to dial it back down. Dist checks out fine ($65 test by Porsche mech in Campbell). The guys at PH suggest maybe the fuel pressure sensor (grenade) has failed. I have limited troubleshooting skills and budget and was hoping to get back into AX this year after a long hiatus so any suggestions will be much appreciated. Thanks in advance !! |
achman_73_2.0 |
Newbie ![]() Group: Members Posts: 40 Joined: 28-October 13 From: NYC Member No.: 16,577 Region Association: Upper MidWest ![]() |
I chased a similar issue for a year with my 2.0 FI '73
Turned out to be a small leak in intake manifold Caused engine to run lean under load, and with a high idle to prevent stalling... I would check that before the MPS (I wish I had!) It's a cheaper fix than getting that rebuilt etc. |
Lo-Fi Version | Time is now: 25th June 2024 - 11:27 PM |
