> Steering rack rebuild, seal and bearing numbers
Olympic 914
post Jan 8 2016, 09:09 AM
Thought I would install my Turbo tie rod ends and found that one of the rack end bushings had stuck to the rack and pushed it out. ( probably during storage )
I found a rack rebuild thread by Wes V
http://www.914world.com/bbs2/index.php?showtopic=95747
But it seems his rack is different than mine. his is a 75 mine is a 73 . I didn't know they changed them.
So it looks like I will have to disassemble my rack and clean up / polish the rack rod.
problem is I can't seem to find a number for the seal. Part #10 in diagram
Also the 911 rack ( and later 914 rack ? ) has a needle bearing at the top whereas, it looks like the 73 rack has caged ball bearings top and bottom.
My rack part number is 914.347.014.00
I haven't disassembled mine yet.
Does anyone have part numbers for the bearings and the seal? are the caged rollers the same number as in the 911 rack? # 6202. and if I can't find the seal could I just go with a sealed 6202 bearing (if available) on the top and skip the #10 seal?
I put PB blaster on the stuck end bushing last night and will work on it later today.
Olympic 914
post Jan 11 2016, 07:01 AM
Ok I got the rack disassembled and found the end bushing is really stuck on there.
I am reluctant to try heat since it will ruin the rubber on the bushing and after much searching I am unable to find a source for replacement end bushings.
It looks like this one will have to be destroyed removing it. I can then polish the rack rod.
Does anyone know of a source for the bushings? or have a good used one they would part with?
I did get the seal out with the numbers intact and have the bearing numbers now.
DavidSweden
post Jan 11 2016, 02:53 PM
QUOTE(Olympic 1.7 @ Jan 11 2016, 05:01 AM) *
The end bushing is probably ok, I left mine alone. As you say you will probably destroy them if you try remove them and i do not believe replacements are available but I may be wrong. The cost of the bearings and seal are minimal so if you rebuild and the end bushes are bad then you haven't lost anything only time.
Olympic 914
post Jan 11 2016, 04:08 PM
QUOTE(DavidSweden @ Jan 11 2016, 03:53 PM) *
the problem is the bushing is frozen onto the rack rod, not inside the casting.
when the bushing is in place and held with the snap rings the rack will not move.
I saw a couple month old thread on the bird board where member said they were manufacturing replacement bushings, and posted a picture. however I don't know the name of the business. I did find an email address and sent an email today inquiring about the parts. So we will see if I get a response..
Olympic 1.7   Steering rack rebuild   Jan 8 2016, 09:09 AM
DavidSweden   Thought I would install my Turbo tie rod ends and...   Jan 8 2016, 10:52 AM
Olympic 1.7   Ok I got the rack disassembled and found the end b...   Jan 11 2016, 07:01 AM
DavidSweden   Ok I got the rack disassembled and found the end ...   Jan 11 2016, 02:53 PM
Olympic 1.7   The end bushing is probably ok, I left mine alon...   Jan 11 2016, 04:08 PM
jmill   Good racks should be easy to find. I swapped mine...   Jan 11 2016, 01:24 PM
MikeM   Contact Bruce Stone. I bought a really nice used o...   Jan 11 2016, 04:20 PM
r_towle   Dunk the end with th bushing into kerosene for a f...   Jan 11 2016, 05:40 PM
Olympic 1.7   Sounds good, I'll give it a try.....   Jan 11 2016, 07:02 PM
Catorse   I went down this road a month ago. None of the thr...   Jan 11 2016, 07:56 PM
Mikey914   Dude, what do you need? I make the pucks for Stodd...   Jan 12 2016, 12:15 PM
r_towle   Dude, what do you need? I make the pucks for Stod...   Jan 12 2016, 02:36 PM
Mikey914   Well I have the #7 cap, I'll look at the #19 I...   Jan 12 2016, 02:38 PM
r_towle   Well I have the #7 cap, I'll look at the #19 ...   Jan 13 2016, 08:44 AM
Mikey914   Well I have the #7 cap, I'll look at the #19...   Jan 14 2016, 01:29 AM
Harpo   That would be awesome if there was a kit with all ...   Jan 13 2016, 12:28 PM
r_towle   Yes, exactly. I believe it was called a short rack...   Jan 14 2016, 07:36 PM
Olympic 1.7   Well finished up the steering rack. Turns out the...   Feb 5 2016, 08:04 PM
r_towle   Very nice   Feb 5 2016, 09:58 PM
turnaround89   What is the little trick to removing the bearing a...   Jan 7 2017, 07:47 PM
Olympic 1.7   What is the little trick to removing the bearing ...   Jan 9 2017, 08:09 AM
Mikey914   Bearing puller. It's been pressed in.   Jan 7 2017, 07:49 PM
turnaround89   Thanks for the replies. I ended up buying a beat...   Jan 9 2017, 12:23 PM
Mikey914   One of the reasons I intend to do as a service.   Jan 9 2017, 04:21 PM
turnaround89   Mikey914 - Are you looking into making the bushing...   Jan 9 2017, 06:06 PM
Mikey914   I've already made the bushings on the other th...   Jan 11 2017, 12:24 AM
naro914   I wanted to revive this thread since I am trying t...   Dec 29 2018, 11:50 AM
bbrock   I just did this last weekend. That bushing is the...   Dec 29 2018, 12:52 PM
naro914   Well...looks like it’s not going to work. The pi...   Dec 29 2018, 01:46 PM
Mikey914   We’ve found 4 different versions of the racks. C...   Dec 29 2018, 09:37 PM
Luke M   We’ve found 4 different versions of the racks. ...   Jan 1 2019, 08:20 AM
Mikey914   We do not sell the "kit" as we have foun...   Jan 1 2019, 08:04 PM
Mikey914   Here's what we did   Jan 1 2019, 08:29 PM
Mikey914   another While not perfect still a great part   Jan 1 2019, 08:31 PM
Mikey914   another   Jan 1 2019, 08:31 PM
Mikey914   more   Jan 1 2019, 08:32 PM
Mikey914   We were dong another baked finish, but I like the ...   Jan 1 2019, 08:34 PM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd November 2024 - 05:02 PM
