jPs |
Newbie ![]() Group: Members Posts: 46 Joined: 17-August 04 From: Austin, Texas Member No.: 2,554 ![]() |
Hi all,
Where's the best place to buy the decent quality CV Joints at the best price? My pass. side started popping about a week ago and knew I probably needed replacements but on a short cruise this morning that all got reinforced as the pass side (tire side) broke. After jacking up the teener and starting to take out the half shaft the transmission side balls and cage just feel to the concrete. So it appears I need both ends and guess I just as well replace the drivers side while I'm going through the process. A VW friend told me he got an entire replacement 1/2 shaft for only about $30 more than him ordering just the CV's when his went out in his VW truck. I know mines type IV but there's not a whole lotta places locally that stock this stuff so any parts houses that you can recommend are appreciated and will any VW 1/2's work? |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
sure - here's the essence after the chit-chat is edited out...
QUOTE Can you tell me the exact differences on 914-6 axles. well - i thought i could, but i can't... ETKA says the halfshafts are the same; i'd thought the inner splines were different, but it looks as if the only difference between /4 and /6 - nowadays anyway - is the stub axle. for sure i have one shattered CV, donno if the axle shaft is bent or not (and no real immediate plans to pull them to see...) if we had a plug & play solution to use the bigger 911 or 930 CV's - even if it meant new axle shafts - even if it meant new drive flanges - i bet they would sell. (actually, i wonder how hard it would be to mod the flanges for the 911 10mm bolts; the 8mm stuff has always scared me a little ...) so - it looks as if there is -no- difference at the halfshaft component level ... |
Lo-Fi Version | Time is now: 26th June 2024 - 05:21 AM |
