Just another 2056 build, Misc Questions |
sdoolin |
Jan 13 2016, 04:29 PM
Member Group: Members Posts: 382 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
Yep, I am building a 2056. Have ordered very nearly a complete 2056 engine kit from Type IV Store (LN Engineering). Some questions (I have searched and read MANY threads)...
I have a "spare" 1976 VW Bus short block (no cyl. heads). Assume this will work for a starting point? Issues with oil dipstick? The bus was an automatic so I assume once I remove the "flex plate" that the flywheel from by 914 engine (in car) will bolt up to the crank without issues? Any issues with engine carrier? The bus used a "moustache bar" for mounting to the frame and I am hoping that the cases from the bus/914 are the same for engine mounting? Will re-use existing Crank/rods New crank/rod bearings Will re-use existing cylinders (overbored) KB 96 mm flat topped pistons with Hastings rings Webcam cam (9130 kit from Type IV Store) Type IV Store pushrods, pushrod ends, parkerized lifters, rocker shafts Type IV Store cam bearings Re-use rockers from bus engine? Not sure about this... HAM (Len Hoffman) RS+ spec cylinder heads New Oil pump from Type IV Store New clutch & pressure plate. Re-use flywheel from 914 engine (in the car) Dellorto Dual 40mm carbs, CB Perf manifolds & linkage SSI heat exchangers & Bursch exhaust New fuel pump - will run return lines (have CFR SS Lines in car now and will re-use) Not sure what dizzy to run? I believe I need to check/verify deck height and valve clearance (I know how, just not positive this is required for a 2056 build). I have read a few threads about "setting" compression ration, but do not understand it yet? Anyone have a compression ratio for dummies guide? Anything else I'm missing? Progress so far... |
malcolm2 |
Jan 15 2016, 12:31 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Sorry I did not read thru the whole post and all comments.... maybe I won't cover something mentioned. But my 2 cents:
I have read that if you have a choice, 1. start with a 1.7 case. Clearance is required to build over a 1.8 with it, but I believe they are beefier all 'round. 2. You will hear it all the time... Bus engines push heavy buses, you might be starting with a more worn case mile for mile. 3. Study up on the benefits of using 911 rockers with swivel feet, not a big expense, but you should decide. 4. buy the kit and pull the pressed in oil galley plugs with screw in type. once I put a drill bit on the big ones, they FELL out. Imagine what would happen with oil pressure.... (IMG:style_emoticons/default/blink.gif) 5. I re-used the PP, FW and resurfaced the clutch in my daily driver. Took them all to a shop that specializes in clutches and they made them like new for about $150. 6. on your CR question, Len will be able to tell you the volume of the combustion area in the head. If he is supplying. IIRC mine was something like 55cc? (IMG:style_emoticons/default/confused24.gif) He wrote it with a sharpie on the head. 7. find a copy of Jake's video to go with all the books you should have also purchased... (IMG:style_emoticons/default/aktion035.gif) |
sdoolin |
Jan 15 2016, 06:26 PM
Sorry I did not read thru the whole post and all comments.... maybe I won't cover something mentioned. But my 2 cents: I have read that if you have a choice, 1. start with a 1.7 case. Clearance is required to build over a 1.8 with it, but I believe they are beefier all 'round. 2. You will hear it all the time... Bus engines push heavy buses, you might be starting with a more worn case mile for mile. 3. Study up on the benefits of using 911 rockers with swivel feet, not a big expense, but you should decide. 4. buy the kit and pull the pressed in oil galley plugs with screw in type. once I put a drill bit on the big ones, they FELL out. Imagine what would happen with oil pressure.... (IMG:style_emoticons/default/blink.gif) 5. I re-used the PP, FW and resurfaced the clutch in my daily driver. Took them all to a shop that specializes in clutches and they made them like new for about $150. 6. on your CR question, Len will be able to tell you the volume of the combustion area in the head. If he is supplying. IIRC mine was something like 55cc? (IMG:style_emoticons/default/confused24.gif) He wrote it with a sharpie on the head. 7. find a copy of Jake's video to go with all the books you should have also purchased... (IMG:style_emoticons/default/aktion035.gif) Thanks for suggestions. I am starting with a known 2.0l case (from a bus). Agree on your number 2, cases will get measured before any new parts installed. Will certainly study the 911 swivel feet rockers, my Cam kit came from Type IV Store does include ball-ends for the pushrods. Oil galley plugs will be removed/replaced I have new clutch, PP, and will re-use existing FW (assuming it will bolt to crank - witch I gotta believe it does_ I will speak with Len on CC volume, he and I have already exchanged several messages. I have Raby's video - it is gospel I belive. Thanks again. |
Lo-Fi Version | Time is now: 28th September 2024 - 03:04 PM |
