BeemerSteve |
Member ![]() ![]() Group: Members Posts: 239 Joined: 2-September 15 From: Van Zandt, Wa Member No.: 19,123 Region Association: Pacific Northwest ![]() |
I have the daunting job of clearing out my interior and cutting my tunnel open to repair the clutch tube. Does anyone have tips on doing this job? Do the fuel lines need to be taken out? Humm.......maybe I should if they're still plastic.
I appreciate all your wisdom as I'm trying to gain some on my own. Thanks!! Steve |
PancakePorsche |
Member ![]() ![]() Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None ![]() |
Mine too broke and was good at the firewall. I made a clamshell bracket for the front which was installed using one bolt and did not require any cutting of tunnel. All was done thru shifter opening. Still working good.
Good reason to to properly lube and maintain your clutch cable to prevent this from occurring in the first place. A dry cable housing causes excessive load on the tube. |
BeemerSteve |
Mine too broke and was good at the firewall. I made a clamshell bracket for the front which was installed using one bolt and did not require any cutting of tunnel. All was done thru shifter opening. Still working good. Good reason to to properly lube and maintain your clutch cable to prevent this from occurring in the first place. A dry cable housing causes excessive load on the tube. Did you by chance take any pictures? I'd be curious to see how you did it. |
Lo-Fi Version | Time is now: 27th June 2024 - 06:28 PM |
