pdlightning |
Member ![]() ![]() Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California ![]() |
I know it has been listed before, but time has passed and I needed clarification from the experts that have already completed their conversions.
I am using a Meziere 55 GPM pump on my LS conversion and remember comments that a Toyota Supra or similiar car radiator was utilized .My questions are as follows: Which Meziere pump is best and how was the thermostat handled since it is removed with the stock pump? Am I close to remembering the Toyota Supra radiator? (Thanks Andy) Also, I received the attached response from Meziere and wondered if someone had a water routing diagram to help in designing the system . We do sell the WP316 water pump and others for the conversions. In the typical LS remote water pump you would run the 2 lines coming out of the pump go to the two lower ports on the front of the engine. The two upper port normally tee into 1 line at the engine and the thermostat would go in this line returning to the radiator. (Thanks to Jerry from Meziere) Thanks to all for your continued support and guidance! |
1stworks |
Member ![]() ![]() Group: Members Posts: 491 Joined: 31-March 13 From: colorado Member No.: 15,718 Region Association: None ![]() |
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
I see you sketched an in line thermostat. Wouldn't that configuration bog down the electric WP? Andys |
Lo-Fi Version | Time is now: 6th July 2024 - 01:02 PM |
