BeemerSteve |
Member ![]() ![]() Group: Members Posts: 239 Joined: 2-September 15 From: Van Zandt, Wa Member No.: 19,123 Region Association: Pacific Northwest ![]() |
I have the daunting job of clearing out my interior and cutting my tunnel open to repair the clutch tube. Does anyone have tips on doing this job? Do the fuel lines need to be taken out? Humm.......maybe I should if they're still plastic.
I appreciate all your wisdom as I'm trying to gain some on my own. Thanks!! Steve |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,003 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
I have fixed them with a sheet metal screw and a conduit clamp as a temp......that lasted over 10yrs without an issue.
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
BeemerSteve |
I have fixed them with a sheet metal screw and a conduit clamp as a temp......that lasted over 10yrs without an issue. Second that, here's mine, i did a little blacksmithing on the conduit clamp to get the correct radius size, my 3/8 socket extension has just the right radius, for an anvil ![]() That's what I'm looking to do and it looks like it'd be easy to do without welding. But first I have to open it up to make my assessment of the problem. Thanks for the visual. |
bcheney |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States ![]() |
I have fixed them with a sheet metal screw and a conduit clamp as a temp......that lasted over 10yrs without an issue. Second that, here's mine, i did a little blacksmithing on the conduit clamp to get the correct radius size, my 3/8 socket extension has just the right radius, for an anvil ![]() That's what I'm looking to do and it looks like it'd be easy to do without welding. But first I have to open it up to make my assessment of the problem. Thanks for the visual. What size is the conduit clamp and did you pick it up at Loews, Home Depot or Ace Hardware? What did you use to attach the clamp to the wall...sheet metal screw or nut and bolt?...what sizes...just want o know as much as possible before purchasing the bits. |
Lo-Fi Version | Time is now: 27th June 2024 - 06:31 PM |
