Puebloswatcop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region ![]() |
Okay everyone,
I am in the process of switching over to the European style front turn signal lights. Can anyone tell me what the functions are of each light. Does the bottom light stay on constant? Does the yellow portion function as a parking light and turn signal still? Just trying to get this right. (IMG:style_emoticons/default/smash.gif) Thanks for any help, |
Darren C |
Member ![]() ![]() Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England ![]() |
Fabricated bulb holders
(IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1453290894.1.jpg) Fitted into housings (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1453290894.2.jpg) Cables fed through existing holes inside insulated part of housing (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1453290895.3.jpg) Change amber lens to split clear/amber Feed power to new bulb from removed marker lamp cable. I only ran extra earth for peace of mind. US lamp housings have pins cast to hold the extra power cable. I heat shrunk over old terminal thats made redundant to prevent confusion in what to reconnect. Use standard twin bulb in amber position but only one filament in use (otherwise its a bigger job to change bulb holder) You can check out in more detail in my Build off challenge thread as its updated ! |
jkb944t |
Member ![]() ![]() Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None ![]() |
Fabricated bulb holders Fitted into housings Cables fed through existing holes inside insulated part of housing Change amber lens to split clear/amber Feed power to new bulb from removed marker lamp cable. I only ran extra earth for peace of mind. US lamp housings have pins cast to hold the extra power cable. I heat shrunk over old terminal thats made redundant to prevent confusion in what to reconnect. Use standard twin bulb in amber position but only one filament in use (otherwise its a bigger job to change bulb holder) You can check out in more detail in my Build off challenge thread as its updated ! This info is very helpful since I need to do this next on my car. Now if I can only figure out how to clean the crud off of the outside of the housings so they look nicer. Jeff B |
Darren C |
This info is very helpful since I need to do this next on my car. Now if I can only figure out how to clean the crud off of the outside of the housings so they look nicer. Jeff B Mine were awful, covered in stone guard, tar, sand and dirt. White spirit and a brass bristle detail wire brush got them like you see in the pictures. |
Lo-Fi Version | Time is now: 27th June 2024 - 07:38 PM |
