FS - SS fuel lines, engine compartment lines,, all 4, fuel tank socks, sealing rings, FI hose clamps, grommets |
Rotary'14 |
Aug 15 2010, 11:49 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
I've made this set, it's 9.5 mm SS .028 tubing, and 8mm SS .028. The ends have beads to keep the fuel lines from blowing off. I've bent it and test fitted the prototypes upon my car. They fit very well IMHO.
Engine Compartment $25 each + $15 shipping Engine Compartment set (2 lines) $45 + $15 shipping Tunnel fuel line each $40 + $25 shipping Tunnel fuel line (set of 2)$75 + $35 shipping If ordering a complete set shipping will be $40 in continental US. complete your installation with the following,,, Fuel tank fuel sock $10 Fuel tank sealing ring NLA for now Firewall grommets $2.00 each Engine shelf grommets $4.00 each FI hose clamps $2.00 each or $1.75 each(if you order more than 10) Shipping included if you buy a set of lines. Thanks for looking! Attached thumbnail(s) |
rhodyguy |
Jan 31 2016, 06:58 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,192 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Helped a fellow member install the tunnel lines today. If you buy the whole kit, EVERYTHING is right there. The lines slip into the stock clips on the firewall like butter. Tell the guy you're helping to take off the pass rear tire. (IMG:style_emoticons/default/dry.gif) Repeatedly. (IMG:style_emoticons/default/rolleyes.gif) He will listen to you later. Then it will take about 10 minutes to fish the lines thru. You'll never get the 30+minutes you wasted back before the tire removal. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 26th November 2024 - 11:23 AM |
