mbseto |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,257 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States ![]() |
Funny, I am as nervous starting this thread as I was to start cutting into my car.
I resolved to start a rustoration thread when I made my first cuts, so here it is. I'm hoping the community will pipe in periodically with any, "Don't do that!", "Do it this other way!", "Do this first!", or "Don't forget this!" comments that are appropriate. Any and all guidance will be appreciated. So here's the car as I got it, not quite a year ago: ![]() Started out doing a little engine work to get it running, then drove it around a little bit before starting to take it apart. Took the engine out, put it up on a dolly, took out much of the interior and suspension, and this is how it sits now: ![]() ![]() ![]() After cleaning out the inside and seeing the rust, it was hard to believe we were driving it at all. These are the first cuts, just straightening out the edges of the rust holes really. ![]() More pics coming soon, I'll be documenting the extent of the damage and forming a battle plan. |
mbseto |
Just a suggestion, when I do sheetmetal fab on rusty cars, I weld back in galvanized sheet metal. You can find at sheetmetal fabrication shops or order through metal distributors. At the very minimum, clean n prep metal n spray with weld through/cold galvanizing spray. Welding in untreated metal is just putting in new tin worm food. Thanks for the input. I'm a little leery about welding galvanized steel. I don't have a professional-level shop, my ventilation is just a fan. Planning to have the whole thing grit blasted, rustproofed, and painted. |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:31 AM |
