Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,997 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
I have the popular front hood shox kit on my 914 but I have issues with it. The shox do hold the hood up in the garage quite well. But in the environment with wind, it fails to hold the hood up. The geometry seems off as if the hood is pushed down an inch or 2 it loses all shock resistance and falls very rapidly.
I find it embarrassing to have to put a length of wood to wedge the hood open while I fuel but even more embarrassing to pump with one hand and hold up the hood with the other. These are new shox. Just purchased and installed a few months ago. I think I've installed them correctly. If the hood is pulled down a couple of inches, it flies down with no resistance. The kit seems well designed but the geometry seems off. The shocks on my 911 front hood provide resistance no matter how open the hood is. Question then: What do I have to do to eliminate the "falling hood" syndrom? Add the original spring? Did I do the installation wrong? Help!! My car as it sits. The gas station I stop at always has wind blowing the hood closed. The wooden stand is absolutely necessary with this shox kit. I've gotten hit too many times with a falling hood while refueling. ![]() Here's Camp914's installation. Mine is the same as this. ![]() Here's how Sir Andy solved the hood shock. The geometry here looks better than mine. ![]() Here's another shock (I think it's a shock) solution. ![]() |
Spoke |
Moving the hood attachment point to the hood front hinge bolt did give tremendous force but limited the hood opening angle too much. The hood just didn't open enough.
After some consideration, I decided to stay with the original attachment point on the fender and move the hood hinge attachment point somewhere between the rear bolt and front bolt. To do that I needed something which would allow me to move the attachment point between the 2 hood bolts. I decided to move the shock attachment point 1 inch from the rear hood bolt. To allow for this adjustment, I used a piece of angle iron to mount the shock attachment to the hood. ![]() The difference in angle of the new attachment point and the original attachment point can be seen from these pics. The shock on the passenger side has been modified. When I did both sides, the increase in force seems quite good. Whereas before if the hood would drop 2 inches, it would start falling. Now if I push the hood down 2 inches, it pops back up. I've found I can drop the hood over 1 foot and it will stay there. Now to test it at the gas station with the wind blowing. And BTW, I think the one shock is not as strong as the other and these are both new shocks as of a couple of months ago. ![]() ![]() |
Lo-Fi Version | Time is now: 1st July 2024 - 02:36 AM |
