> Porsche 914 Dash Repair via CFRP Wrapping Process
dovsky
post Feb 2 2016, 08:59 AM
CFRP stands for Carbon Fiber Reinforced Polymer, which is the technical term for what most people refer to as just simply “carbon fiber”. CFRP is a composite material comprised of the carbon fiber itself (in this case in the form of woven fabric) and a formulated resin compound acting as a plasticizer.
In this thread I’ll be showing step-by-step how we (www.compositedimensions.com) were able not only to repair and save a cracked 914 dash, but to also make it look and feel as if it was originally made from CFRP.
Below are a few photos of the dash prior to the repair.
STEP 1 – Crack Sealing. We used a 2-part epoxy putty compound to fill and seal each crack. An unlike most polyester-based body fillers, this compound is compatible with the epoxy resin system used in the later steps.
STEP 2 – Epoxy Based Coat. This base coat provides an ideal black background for the carbon fiber fabric and allows the dash to gain back some of its rigidity at this early stage. After its application, it’s left to reach a “tacky” stage (approx. 4 hours).
STEP 3 – Making Cutting Templates. Carbon fiber fabric is expensive. This particular fabric is $50 per square meter. In order to minimize material waste, cutting templates is a must. This not only saves material but also provides more accurate placement with minimal seems, and eliminates “bridging” on intricate contoured areas. The fabric itself is a high quality 200 grams/sq. meter 2/2 twill 3K.
STEP 4 – Carbon Fiber Wrapping (Dry). While taking advantage of the tacky surface on the base coat, and with the aid of a compatible spray adhesive, the various pre-cut carbon fiber pieces are carefully placed into position. Notice that we also wrapped the visible underside areas.
STEP 5 – Clear Epoxy Resin. Once all the carbon fiber is laid, we applied 3 coats of a specially formulated high viscosity epoxy resin. Minimal sanding in between coats is performed to remove obvious high-spots before allowing the final coat to cure overnight.
All visible areas on the underside are also addressed.
STEP 6 – Sanding (Dry & Wet). The dash was sanded dry using 120 grit paper to remove any remaining high-spots before moving on to wet sanding with progressively finer girt paper (240, 400, 800 and 1200), leaving a smooth satin finish at the end. This is by far the longest process step.
Dash after dry-sanding it with coarse 120 grit paper:
Dash after wet-sanding it with fine 1200 grit paper:
STEP 7 – Finishing. We applied 2 coats of UV-stable high-gloss lacquer. Once cured we then machined-polished all surfaces to achieve a professional finish.
The dash is finally done and ready to be installed back.
Project duration: 2.5 weeks including curing & drying times (epoxy resin and lacquer coats).
Total Labor hours: 45 (most of them spent on surface sanding)
I hope you enjoyed this article. All questions are welcome.
Checkout our other products and services at www.compositedimesnions.com along with our growing 914 Carbon Gear parts catalog where you will find sun visors, center consoles, side mirrors, gauge and trim panels.
Dov
Dov Chartarifsky
CEO – Composite Dimensions
Hameyasdim #62
Zichron Ya'akov
30900, Israel
Tel: +972 (0) 50 4047915
dovsky@bezeqint.net
dov@compositedimensions.com
Andyrew
post Feb 2 2016, 09:31 AM
Spooling.... Please wait
Awesome process! Thanks for sharing!
dovsky   Porsche 914 Dash Repair via CFRP Wrapping Process   Feb 2 2016, 08:59 AM
Andyrew   Awesome process! Thanks for sharing!   Feb 2 2016, 09:31 AM
Coondog   I would put that on my 914. You guys do great work...   Feb 2 2016, 10:07 AM
dovsky   I would put that on my 914. You guys do great wor...   Feb 2 2016, 12:19 PM
Chris Pincetich   :drooley: :beer2:   Feb 2 2016, 10:09 AM
914_teener   Curious...is a fixture used during the layup proce...   Feb 2 2016, 10:37 AM
dovsky   Curious...is a fixture used during the layup proc...   Feb 2 2016, 10:50 AM
Mikey914   I would assume that the carbon fiber is being used...   Feb 2 2016, 10:43 AM
Darren C   Fitting the ashtray would be awkward as the overla...   Feb 2 2016, 10:49 AM
dovsky   Fitting the ashtray would be awkward as the overl...   Feb 2 2016, 10:58 AM
Mikey914   Might want to check the ash tray and the mount in ...   Feb 2 2016, 10:57 AM
dovsky   Might want to check the ash tray and the mount in...   Feb 2 2016, 11:02 AM
Hank914   Might want to check the ash tray and the mount i...   Feb 2 2016, 12:33 PM
Darren C   I'd wait until you get feedback from the origi...   Feb 2 2016, 11:07 AM
dovsky   I'd wait until you get feedback from the orig...   Feb 2 2016, 11:19 AM
Jeff Bowlsby   The last thing anyone would want on any dashboard ...   Feb 2 2016, 11:20 AM
dovsky   The last thing anyone would want on any dashboard...   Feb 2 2016, 12:01 PM
Justinp71   Looks Great! Two questions- how much is it to ...   Feb 2 2016, 12:59 PM
dovsky   Looks Great! Two questions- how much is it to...   Feb 2 2016, 01:15 PM
Justinp71   Looks Great! Two questions- how much is it t...   Feb 2 2016, 01:45 PM
dovsky   [quote name='dovsky' post='2297456' date='Feb 2 2...   Feb 2 2016, 02:25 PM
Chris914n6   The part that overhangs the gauges is supposed to ...   Feb 2 2016, 02:22 PM
dovsky   The part that overhangs the gauges is supposed to...   Feb 2 2016, 02:34 PM
sixnotfour   Looks Great,, there was a member that was making C...   Feb 2 2016, 02:31 PM
Sedonut   I had the opportunity to be the first customer. Wi...   Feb 2 2016, 09:41 PM
76-914   I had the opportunity to be the first customer. W...   Feb 3 2016, 08:24 AM
r_towle   Kind of a silly question, but given these dash pad...   Feb 2 2016, 10:08 PM
Sedonut   Shipping the core is not a problem, if it picks up...   Feb 3 2016, 07:35 AM
Chris914n6   ^^ dash mat. easy.   Feb 3 2016, 02:49 PM
Sedonut   Received my dash safely today. It only took 7 days...   Feb 11 2016, 10:44 AM
3d914   Received my dash safely today. It only took 7 day...   Feb 11 2016, 01:43 PM
dovsky   Received my dash safely today. It only took 7 day...   Feb 12 2016, 04:58 AM
fiberglass1inc   What do you do for UV resistance? Most epoxies yel...   Feb 11 2016, 04:56 PM
dovsky   What do you do for UV resistance? Most epoxies ye...   Feb 12 2016, 05:07 AM
fiberglass1inc   While laying up a carbon part I noticed that the...   Feb 11 2016, 05:06 PM
fiberglass1inc   Installed under dash   Feb 11 2016, 05:44 PM
14 User(s) are reading this topic (14 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 5th February 2025 - 06:51 AM
