1970 porsche 914 ignition switch wiring, How does original ignition switch differ from new aftermarket switch. |
radobard |
Feb 3 2016, 10:19 AM
Newbie Group: Members Posts: 2 Joined: 15-January 16 From: San Antonio, TX Member No.: 19,563 Region Association: None |
I just replaced my ignition switch on my 1970 porsche 914 4. The replacement switches have four wires connected , red, red/white, black, and grey. My original switch had five wires, red, red/black, black, grey, and a copper see through wire. First question, does the red/ white wire on the original replace the red/black wire on the new? Second question, what is the function of the copper see through wire? If I don't have it in the replacement switch, will something not work? Here is a photo of an original switch with the five wires. The see through copper looking wire is at the top.
McMark |
Feb 4 2016, 09:00 AM
The see-thru wire looks like a ground. I'd use an ohmmeter to confirm all the wire functions before I installed it.
mark04usa |
Feb 4 2016, 12:04 PM
'70 1.7 Tangerine Group: Members Posts: 352 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
The see-thru wire looks like a ground. I'd use an ohmmeter to confirm all the wire functions before I installed it. I replace the ignition swith on my '70 914 recently. You'll need to unsolder the connectors and reuse them to fit the wiring back into the connector as shown. Be sure to cut the wires to precise length needed. The copper "see-through" wire is a ground. |
Lo-Fi Version | Time is now: 15th January 2025 - 02:25 AM |
