Pass side view mirror |
SKL1 |
Feb 3 2016, 06:14 PM
Senior Member Group: Members Posts: 1,612 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Thinking of putting a side view mirror on pass side of my '73. If I remember correctly when havin the panel off, the nuts are welded in place on the inside for the screws aren't they? Even though it would pain me to do it, you could drill from the inside through those to create the holes?
Can you just turn the mirror around to use a spare mirror from the driver's side, or it a different part number for right (pass) side? I may chicken out when it comes to drilling the holes though (IMG:style_emoticons/default/blink.gif) |
Vysoc |
Feb 4 2016, 04:06 PM
Vysoc Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
Cmon SKL1,
You are from Iowa, you can do this, I hit mine square in the middle on the first try! It is in exactly the same location as the drivers side, use your mirror gasket as your template and drill your pilot hole with small diameter drill bit. With the window up you can feel and see (Flashlight) if you hit your mark! Good luck and put tape down before you drill. Vysoc (IMG:style_emoticons/default/flag.gif) |
Lo-Fi Version | Time is now: 29th June 2024 - 08:25 AM |
