> Project 914 1.8T, Some pics of the conversion...
914_1.8t
post Sep 25 2004, 07:14 PM
I've enjoyed seeing pics of everyones cars and buildups. Few people wanted me to post some pics of the work in progress and I finally found my digital camera, so here are a few pics:
Mueller
post Sep 29 2004, 02:45 PM
914 Freak!
Thanks, i'll stop by and talk to them about the adapters and see how much they would want for them. Probobly tomorrow.
I'm sorry, I should have been more specific...they only sell raw steel, they'll look at you crazy if you ask about adapters and such (IMG:style_emoticons/default/smile.gif)
oh yea, make sure you wear shoes, I normally wear sandels (I'm a slacker) and I got a lecture by the owner of the place (IMG:style_emoticons/default/headbang.gif)
914_1.8t   Project 914 1.8T   Sep 25 2004, 07:14 PM
914_1.8t   Above was a pic from the back showing the sub-fram...   Sep 25 2004, 07:16 PM
914_1.8t   Pic of ground/engine clearance from under car:   Sep 25 2004, 07:17 PM
914_1.8t   Pic from below of turbo almost hitting battery tra...   Sep 25 2004, 07:18 PM
914_1.8t   Seat that I will be using (from late model RX7) an...   Sep 25 2004, 07:19 PM
914_1.8t   I pushed the fender out sightly (about 2"), when t...   Sep 25 2004, 07:22 PM
914_1.8t   So, i've managed to get the motor started but ...   Sep 25 2004, 07:26 PM
Hi_Fi_Guy   Very cool project. Besides all the obvius stuff we...   Sep 25 2004, 07:55 PM
bob91403   Seat looks good. Does it give enough room for the ...   Sep 25 2004, 08:10 PM
scott thacher   quik ? which tranny are you using and how do you...   Sep 26 2004, 01:44 AM
914_1.8t
  Sep 27 2004, 01:27 PM
914_1.8t   <...   Sep 27 2004, 01:53 PM
Mueller
  Sep 27 2004, 02:08 PM
Cloudbuster   As for halfshafts, I'm quite sure you can get ...   Sep 27 2004, 02:12 PM
freezing14   hey mike,, I went to the link read the whole thi...   Sep 27 2004, 02:25 PM
lapuwali   It's not uncommon to make up axles by just tak...   Sep 27 2004, 02:26 PM
freezing14   I have no reference for this but i would think tha...   Sep 27 2004, 02:29 PM
914_1.8t   <...   Sep 27 2004, 03:39 PM
Aaron Cox   is this a 6 speed? mate this trans to a type 4 o...   Sep 27 2004, 04:04 PM
75boxster   SKS on Audiworld.com did this conversion a couple ...   Sep 27 2004, 11:31 PM
Mueller
  Sep 27 2004, 11:48 PM
75boxster   You are probably right about the SKS car. I have ...   Sep 28 2004, 09:14 AM
914_1.8t   <...   Sep 28 2004, 09:37 AM
neo914-6
  Sep 28 2004, 03:44 PM
Mueller   Felix, I couldn't find the axle adapters on t...   Sep 28 2004, 04:19 PM
neo914-6   Mike, Here a pic: RH axle adapter Felix   Sep 28 2004, 04:28 PM
Mueller   thanks Felix........I'd say those are steel, I...   Sep 28 2004, 04:43 PM
andys   Try these guys for the axles; I think they do spec...   Sep 28 2004, 05:38 PM
neo914-6
  Sep 28 2004, 11:53 PM
Andyrew   Looks like it started from a 914... Counts as a 91...   Sep 29 2004, 12:20 AM
Mueller   well....i stand corrected, it is/was a 914 :)   Sep 29 2004, 12:44 AM
914_1.8t   <...   Sep 29 2004, 12:41 PM
Mueller   Fremont Steel off of Fremont Blvd, in Fremont :), ...   Sep 29 2004, 01:38 PM
914_1.8t   Thanks, i'll stop by and talk to them about th...   Sep 29 2004, 02:06 PM
Mueller
fiid   Bayshore Metals in San Francisco can help you with...   Sep 29 2004, 03:13 PM
914_1.8t   Update... Before I could get the enfine to fire u...   Oct 6 2004, 07:03 PM
914_1.8t   Radiator with some misc radiator hoses I found at ...   Oct 6 2004, 07:07 PM
914_1.8t   Pic of the car: Still need to work on those 1/4 pa...   Oct 6 2004, 07:08 PM
914_1.8t   oops...lets try again: I think i will need adjusta...   Oct 6 2004, 07:10 PM
914_1.8t   One more from the side... Paint looks pretty crapp...   Oct 6 2004, 07:12 PM
neo914-6   Good job getting it running! :trophy: I'l...   Oct 7 2004, 12:49 AM
neo914-6   "Sonu" (sorry for the misspelling), It was good t...   Oct 11 2004, 12:31 AM
neo914-6   I just realized I may have 911 axles when I purcha...   Oct 11 2004, 12:48 AM
James Adams   Check out these axles. Many different lengths (15...   Oct 11 2004, 06:05 AM
914_1.8t
  Oct 12 2004, 12:44 AM
neo914-6   The axle overall length is 23 1/2" The outer CV fa...   Oct 12 2004, 12:57 AM
neo914-6   Axle end..   Oct 12 2004, 01:01 AM
neo914-6   CV end...   Oct 12 2004, 01:02 AM
fiid   What does the audi gearbox output shaft flange loo...   Oct 12 2004, 10:31 AM
914_1.8t     Oct 12 2004, 01:41 PM
914_1.8t   ...   Oct 13 2004, 11:21 AM
914_1.8t     Oct 13 2004, 12:11 PM
fiid   This looks totally do-able. The 911 driveshafts a...   Oct 13 2004, 12:50 PM
914_1.8t     Oct 13 2004, 12:57 PM
914_1.8t   Audi Trans:   Oct 13 2004, 12:57 PM
914_1.8t   Boster trans:   Oct 13 2004, 12:58 PM
914_1.8t   Another of boxster trans:   Oct 13 2004, 01:31 PM
914_1.8t   try again: By the way, does anyone have a pic of ...   Oct 13 2004, 01:32 PM
fiid   A quattro tranny would work if you freeze (weld?) ...   Oct 13 2004, 01:37 PM
andys   ...   Oct 13 2004, 02:09 PM
neo914-6   Sonu, Your Audi output flanges must be 108mm to f...   Jun 4 2005, 01:10 PM
- Lo-Fi Version Time is now: 29th April 2025 - 06:29 PM
