> Powder coating parts
post Feb 5 2016, 06:32 AM
914-6 GT in waiting
My suggestion is to find a local place in an industrial park that will work with you. Our local place isn't pretty and my order isn't typical (they mostly do patio furniture and aluminum awnings). $275 got all this done and my 914-6 tank. Everything looked like crap on the way in.
tomrev
post Feb 5 2016, 06:57 AM
QUOTE(mepstein @ Feb 5 2016, 04:32 AM) *
Exactly! The place where I live will do the parts cheaper than I can rattle-can them. A few years back, they did a full tube frame for a Lotus 23, and 35 individual suspension, engine mount, etc. bits for $235. Their usual stuff is large cherry lugs for the local farm industry.
mepstein   Powder coating parts   Feb 5 2016, 06:32 AM
tomrev   My suggestion is to find a local place in an indu...   Feb 5 2016, 06:57 AM
BK911   Local guy did 23 pieces for $100. Blasting a...   Feb 5 2016, 07:53 AM
mepstein   Started in with them a couple years ago when I lef...   Feb 5 2016, 08:07 AM
McMark   Started in with them a couple years ago when I le...   Feb 5 2016, 09:37 AM
aircooledtechguy   I haven't painted parts in about 10 years. Po...   Feb 5 2016, 08:54 AM
Larmo63   Do it right if you are going to do it. Powder coat...   Feb 5 2016, 08:59 AM
Tom_T   Do it right if you are going to do it. Powder coa...   Feb 5 2016, 01:19 PM
Boomingbeetle   You should post the shop so others in SoCal/OC/S...   Nov 2 2016, 08:06 PM
PanelBilly   I've had some problems when the coating was ap...   Feb 5 2016, 09:19 AM
mbseto   Any rec's for the Cinci area?   Feb 5 2016, 09:42 AM
Eric_Shea   BTDT... all the time. Biggest thing is to go lig...   Feb 5 2016, 11:27 AM
mepstein   BTDT... all the time. Biggest thing is to go li...   Feb 5 2016, 12:24 PM
Eric_Shea   BTDT... all the time. Biggest thing is to go l...   Feb 8 2016, 05:55 PM
mepstein   [quote name='mepstein' post='2298940' date='Feb 5...   Feb 8 2016, 06:17 PM
Tom_T   Mark, Since they all mostly use the same PC color...   Feb 5 2016, 12:44 PM
mepstein   Mark, Since they all mostly use the same PC colo...   Feb 5 2016, 01:09 PM
Tom_T   Honestly, all I told them was run everything semi...   Feb 5 2016, 01:13 PM
falcor75   Just remember to remove the powdercoat where impor...   Feb 6 2016, 12:29 AM
Eric_Shea   I'll shut up now. :blink:   Feb 8 2016, 10:47 PM
mepstein   I'll shut up now. :blink: Not at all. I appr...   Feb 9 2016, 06:28 AM
Amphicar770   Looks great and that is awesome pricing. I took ...   Feb 17 2016, 07:10 PM
Amphicar770   BTW, should you need to remove powder coat ... CRC...   Feb 17 2016, 07:14 PM
jkb944t   BTW, should you need to remove powder coat ... CR...   Feb 23 2016, 07:28 AM
Puebloswatcop   :trophy: Man your parts look awesome. I see sever...   Feb 17 2016, 08:04 PM
saigon71   Those parts look great! I'm about 24 ho...   Feb 22 2016, 05:22 PM
mepstein   I just sent over one of Ben's new aluminum 914...   Feb 22 2016, 05:58 PM
jkb944t   My Elephant Racing poly-bronze bushings slide over...   Feb 23 2016, 07:25 AM
db9146   Kypton tape can be used to mask off areas prior to...   Feb 23 2016, 10:32 PM
- Lo-Fi Version Time is now: 12th April 2025 - 03:15 AM
