> Powder coating parts
post Feb 5 2016, 06:32 AM
914-6 GT in waiting
My suggestion is to find a local place in an industrial park that will work with you. Our local place isn't pretty and my order isn't typical (they mostly do patio furniture and aluminum awnings). $275 got all this done and my 914-6 tank. Everything looked like crap on the way in.
Tom_T
post Feb 5 2016, 12:44 PM
TMI....
Mark,
Since they all mostly use the same PC color charts & materials, how was the color & finish match to the OE satin black used on your -6 parts as painted from the factory? (IMG:style_emoticons/default/confused24.gif)
I had interior parts on my `88 Westy PC'd with a local guy my body shop uses, & we got an excellent match for it's factory color, but they were more of a semi-gloss or gloss originally.
Just wondering if they'd be able to match the factory black satin for my 73 2L's parts in the resto?
- essentially the same set of parts as as what you've done for your -6.
TIA (IMG:style_emoticons/default/beerchug.gif)
Tom
post Feb 5 2016, 01:09 PM
914-6 GT in waiting
QUOTE(Tom_T @ Feb 5 2016, 01:44 PM) *
Mark,
Tom
Honestly, all I told them was run everything semigloss black. I also had 4 sets of 911 engine tin including a set of '76 turbo tin. Their semi black was a dead match for the turbo tin and that's what we needed. 2% of the cars we do are original restorations. The rest are hot rods. Hot rods are easier because we make them look the way we want, not the way we think some judge wants.
mepstein   Powder coating parts   Feb 5 2016, 06:32 AM
tomrev   My suggestion is to find a local place in an indu...   Feb 5 2016, 06:57 AM
BK911   Local guy did 23 pieces for $100. Blasting a...   Feb 5 2016, 07:53 AM
mepstein   Started in with them a couple years ago when I lef...   Feb 5 2016, 08:07 AM
McMark   Started in with them a couple years ago when I le...   Feb 5 2016, 09:37 AM
aircooledtechguy   I haven't painted parts in about 10 years. Po...   Feb 5 2016, 08:54 AM
Larmo63   Do it right if you are going to do it. Powder coat...   Feb 5 2016, 08:59 AM
Tom_T   Do it right if you are going to do it. Powder coa...   Feb 5 2016, 01:19 PM
Boomingbeetle   You should post the shop so others in SoCal/OC/S...   Nov 2 2016, 08:06 PM
PanelBilly   I've had some problems when the coating was ap...   Feb 5 2016, 09:19 AM
mbseto   Any rec's for the Cinci area?   Feb 5 2016, 09:42 AM
Eric_Shea   BTDT... all the time. Biggest thing is to go lig...   Feb 5 2016, 11:27 AM
mepstein   BTDT... all the time. Biggest thing is to go li...   Feb 5 2016, 12:24 PM
Eric_Shea   BTDT... all the time. Biggest thing is to go l...   Feb 8 2016, 05:55 PM
mepstein   [quote name='mepstein' post='2298940' date='Feb 5...   Feb 8 2016, 06:17 PM
Tom_T   Mark, Since they all mostly use the same PC color...   Feb 5 2016, 12:44 PM
mepstein   Mark, Since they all mostly use the same PC colo...   Feb 5 2016, 01:09 PM
Tom_T   Honestly, all I told them was run everything semi...   Feb 5 2016, 01:13 PM
falcor75   Just remember to remove the powdercoat where impor...   Feb 6 2016, 12:29 AM
Eric_Shea   I'll shut up now. :blink:   Feb 8 2016, 10:47 PM
mepstein   I'll shut up now. :blink: Not at all. I appr...   Feb 9 2016, 06:28 AM
Amphicar770   Looks great and that is awesome pricing. I took ...   Feb 17 2016, 07:10 PM
Amphicar770   BTW, should you need to remove powder coat ... CRC...   Feb 17 2016, 07:14 PM
jkb944t   BTW, should you need to remove powder coat ... CR...   Feb 23 2016, 07:28 AM
Puebloswatcop   :trophy: Man your parts look awesome. I see sever...   Feb 17 2016, 08:04 PM
saigon71   Those parts look great! I'm about 24 ho...   Feb 22 2016, 05:22 PM
mepstein   I just sent over one of Ben's new aluminum 914...   Feb 22 2016, 05:58 PM
jkb944t   My Elephant Racing poly-bronze bushings slide over...   Feb 23 2016, 07:25 AM
db9146   Kypton tape can be used to mask off areas prior to...   Feb 23 2016, 10:32 PM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 12th April 2025 - 03:22 AM
