> Steering rack rebuild, seal and bearing numbers
Olympic 914
post Jan 8 2016, 09:09 AM
Thought I would install my Turbo tie rod ends and found that one of the rack end bushings had stuck to the rack and pushed it out. ( probably during storage )
I found a rack rebuild thread by Wes V
http://www.914world.com/bbs2/index.php?showtopic=95747
But it seems his rack is different than mine. his is a 75 mine is a 73 . I didn't know they changed them.
So it looks like I will have to disassemble my rack and clean up / polish the rack rod.
problem is I can't seem to find a number for the seal. Part #10 in diagram
Also the 911 rack ( and later 914 rack ? ) has a needle bearing at the top whereas, it looks like the 73 rack has caged ball bearings top and bottom.
My rack part number is 914.347.014.00
I haven't disassembled mine yet.
Does anyone have part numbers for the bearings and the seal? are the caged rollers the same number as in the 911 rack? # 6202. and if I can't find the seal could I just go with a sealed 6202 bearing (if available) on the top and skip the #10 seal?
I put PB blaster on the stuck end bushing last night and will work on it later today.
Olympic 914
post Feb 5 2016, 08:04 PM
Well finished up the steering rack.
Turns out the end bushings are really NLA...
managed to save mine. put a little heat on the rack and with some more PB blaster I got them to move. then shined the rack up with some fine emery cloth on the lathe.
Ready for the new bearings..
and these are the bearings that are used .
FAG 16002
and the seal is a 40x28x7 single lip
SKF 564085
if any one is thinking about doing this, it really is not a hard job. little trick getting out the lower bearing but other than that its a straight forward job.
good idea to mark the rack and housing with a dot of paint so they go back together the same way.
Done.
Olympic 1.7   Steering rack rebuild   Jan 8 2016, 09:09 AM
DavidSweden   Thought I would install my Turbo tie rod ends and...   Jan 8 2016, 10:52 AM
Olympic 1.7   Ok I got the rack disassembled and found the end b...   Jan 11 2016, 07:01 AM
DavidSweden   Ok I got the rack disassembled and found the end ...   Jan 11 2016, 02:53 PM
Olympic 1.7   The end bushing is probably ok, I left mine alon...   Jan 11 2016, 04:08 PM
jmill   Good racks should be easy to find. I swapped mine...   Jan 11 2016, 01:24 PM
MikeM   Contact Bruce Stone. I bought a really nice used o...   Jan 11 2016, 04:20 PM
r_towle   Dunk the end with th bushing into kerosene for a f...   Jan 11 2016, 05:40 PM
Olympic 1.7   Sounds good, I'll give it a try.....   Jan 11 2016, 07:02 PM
Catorse   I went down this road a month ago. None of the thr...   Jan 11 2016, 07:56 PM
Mikey914   Dude, what do you need? I make the pucks for Stodd...   Jan 12 2016, 12:15 PM
r_towle   Dude, what do you need? I make the pucks for Stod...   Jan 12 2016, 02:36 PM
Mikey914   Well I have the #7 cap, I'll look at the #19 I...   Jan 12 2016, 02:38 PM
r_towle   Well I have the #7 cap, I'll look at the #19 ...   Jan 13 2016, 08:44 AM
Mikey914   Well I have the #7 cap, I'll look at the #19...   Jan 14 2016, 01:29 AM
Harpo   That would be awesome if there was a kit with all ...   Jan 13 2016, 12:28 PM
r_towle   Yes, exactly. I believe it was called a short rack...   Jan 14 2016, 07:36 PM
Olympic 1.7   Well finished up the steering rack. Turns out the...   Feb 5 2016, 08:04 PM
r_towle   Very nice   Feb 5 2016, 09:58 PM
turnaround89   What is the little trick to removing the bearing a...   Jan 7 2017, 07:47 PM
Olympic 1.7   What is the little trick to removing the bearing ...   Jan 9 2017, 08:09 AM
Mikey914   Bearing puller. It's been pressed in.   Jan 7 2017, 07:49 PM
turnaround89   Thanks for the replies. I ended up buying a beat...   Jan 9 2017, 12:23 PM
Mikey914   One of the reasons I intend to do as a service.   Jan 9 2017, 04:21 PM
turnaround89   Mikey914 - Are you looking into making the bushing...   Jan 9 2017, 06:06 PM
Mikey914   I've already made the bushings on the other th...   Jan 11 2017, 12:24 AM
naro914   I wanted to revive this thread since I am trying t...   Dec 29 2018, 11:50 AM
bbrock   I just did this last weekend. That bushing is the...   Dec 29 2018, 12:52 PM
naro914   Well...looks like it’s not going to work. The pi...   Dec 29 2018, 01:46 PM
Mikey914   We’ve found 4 different versions of the racks. C...   Dec 29 2018, 09:37 PM
Luke M   We’ve found 4 different versions of the racks. ...   Jan 1 2019, 08:20 AM
Mikey914   We do not sell the "kit" as we have foun...   Jan 1 2019, 08:04 PM
Mikey914   Here's what we did   Jan 1 2019, 08:29 PM
Mikey914   another While not perfect still a great part   Jan 1 2019, 08:31 PM
Mikey914   another   Jan 1 2019, 08:31 PM
Mikey914   more   Jan 1 2019, 08:32 PM
Mikey914   We were dong another baked finish, but I like the ...   Jan 1 2019, 08:34 PM
18 User(s) are reading this topic (18 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd November 2024 - 05:42 PM
