Rear wheel bearing replacement, Parts needed? |
JawjaPorsche |
Nov 14 2012, 01:12 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
My right rear bearing is making noises. I called my mechanic and he said to get parts and he would install it.
I am looking at the exploded view of rear axle. (See below) When I order parts, do I just need the Bearing #28? Is there a race for the control arm because I don't see one? Does he need to remove CV axle and tap out the bearing from the inside? Thank you in advance for your help. Attached thumbnail(s) |
veekry9 |
Feb 10 2016, 12:46 AM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
.......No hammers allowed. ^ Agreed, If a proper press or extractor is not available,a hammer is the way to damage the bearing. Cooking the bearings in clean oil to above 212 F,more like 300 F,will allow the bearing to slip onto a chilled shaft. Both must be checked for actual dimensions and the resulting interference at operational temperature.SOP. Roller bearing crankshafts and spindles have certain required methods. Induction heating of bearings or housings is another way,production oriented. https://www.google.ca/webhp?sourceid=chrome...=bearings%20101 https://www.google.ca/webhp?sourceid=chrome...%20installation https://www.google.ca/search?q=bearing+pull...anSDP0Q_AUIBigB In the machine trade,smoking a 30K$ machine bearing is not an option,therefore expertise and experience is applied. / |
Lo-Fi Version | Time is now: 16th September 2024 - 01:42 PM |
