I Admit It, I Haven't Seen it All......, Help now, laugh later..... |
Series9 |
Feb 10 2016, 01:44 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
As a VW/Porsche professional, there are always a few things you think about. You know, common things you haven't done yet. Go ahead and laugh: I'm changing my first swing-axle transmission today. 1965 T-34. First, here are my thoughts on the swing-axle design: (IMG:style_emoticons/default/dry.gif) Here's where I need help: The left and right sides had different spacers between the wheel bearing and the hub. Which one is correct? They are very different thicknesses, and one has an inside chamfer while the other has an outside. I took them both off before I noticed the difference, so I can't tell you which was where. What I can tell you it the LR brakes were totally covered in gear oil. Help, please. (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
Mark Henry |
Feb 10 2016, 02:06 PM
You need 2 of the left, the bevel goes against the axle.
The swing hardware changed over the years, there is also 3 different lengths of axles and tubes. Just for shits and giggles check to see if both sides are the same length. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:24 PM |
