> BUILD-OFF CHALLENGE: Barn find with 50k original miles
Matty900
post Feb 4 2016, 03:05 PM
Looking forward to working on this project so I can drive my own car to WCR 2016Attached Image
Matty900
post Feb 11 2016, 01:44 AM
I was able to get a better look at the car today. It really is pretty solid. I did get some better pictures of it and in looking at the hell hole, I can see that the rust has go all the way through the metal in some pin holes.
Matty900   BUILD-OFF CHALLENGE: Barn find with 50k original miles   Feb 4 2016, 03:05 PM
CatDaddy60   Good on ya, send more pictures!!!   Feb 4 2016, 03:23 PM
Matty900   Here's the important picture. Seems to be a li...   Feb 4 2016, 08:19 PM
Matty900   Fuchs wheels including the spare wheel and the ori...   Feb 4 2016, 08:21 PM
Matty900   Needs some interior help. Luckily I know where to ...   Feb 4 2016, 08:24 PM
Matty900   Little bit of surface rust in trunk   Feb 4 2016, 08:26 PM
Matty900   Not too bad   Feb 4 2016, 08:28 PM
Matty900   Needs a new master cylinder or rebuild   Feb 4 2016, 08:30 PM
euro911   I'd just get a NEW M/C ... rebuild kits aren...   Feb 4 2016, 08:31 PM
Matty900   I'd just get a NEW M/C ... rebuild kits aren...   Feb 4 2016, 08:39 PM
euro911   I'd just get a NEW M/C ... rebuild kits aren...   Feb 4 2016, 11:18 PM
914Sixer   Inside storage SAVED the car!   Feb 4 2016, 08:45 PM
iwanta914-6   I'll never understand how people find these ca...   Feb 4 2016, 09:37 PM
hot_shoe914   I'll never understand how people find these c...   Mar 9 2016, 08:57 PM
Hank914   I'll never understand how people find these ...   Mar 9 2016, 10:34 PM
Larmo63   Your picture is not a picture of the master cylind...   Feb 4 2016, 10:02 PM
Matty900   Your picture is not a picture of the master cylin...   Feb 4 2016, 10:38 PM
Matty900   Your picture is not a picture of the master cyli...   Feb 4 2016, 10:54 PM
whitetwinturbo   :Qarl: :wttc: :Qarl:   Feb 4 2016, 10:53 PM
Matty900   :Qarl: :wttc: :Qarl: Thanks for the interesti...   Feb 4 2016, 11:12 PM
Mr.Nobody   :Qarl: :wttc: :Qarl: My car came off the lin...   Mar 26 2016, 09:25 PM
Larmo63   A somewhat early '72, nice vintage. When do we...   Feb 4 2016, 10:54 PM
Matty900   A somewhat early '72, nice vintage. When do w...   Feb 6 2016, 02:15 AM
mgp4591   Wild looking wide body- any other pictures of that...   Feb 4 2016, 11:32 PM
Matty900   Wild looking wide body- any other pictures of tha...   Feb 5 2016, 01:18 AM
pete000   Nice find !   Feb 4 2016, 11:44 PM
cwpeden   You have 2 now? Whats wrong with the wide body?   Feb 5 2016, 01:56 AM
Matty900   You have 2 now? Whats wrong with the wide body? ...   Feb 5 2016, 03:11 AM
veekry9   :wttc: Fun with 14's. Nice catch,a '7...   Feb 5 2016, 07:40 AM
Matty900   veekry9 Thanks for the links. There is a lot of co...   Feb 6 2016, 01:36 AM
Matty900   :wttc: Fun with 14's. Nice catch,a ...   Feb 10 2016, 02:49 AM
veekry9   Seems a guy has made it happen,and I'm sure...   Feb 6 2016, 02:10 AM
veekry9   All of the suspension rubber is likely beat and de...   Feb 6 2016, 02:40 AM
Matty900   All of the suspension rubber is likely beat and d...   Feb 6 2016, 04:09 AM
euro911   Just info, you mentioned the engine was built to a...   Feb 6 2016, 10:27 AM
Matty900   Just info, you mentioned the engine was built to ...   Feb 6 2016, 01:58 PM
euro911   It all depends on which route the builder took. St...   Feb 7 2016, 01:06 AM
Dave_Darling   The case would not need to be cut, just the heads....   Feb 7 2016, 12:13 PM
Matty900   The case would not need to be cut, just the heads...   Feb 7 2016, 02:14 PM
Dave_Darling   So I need to expect that at some point I will need...   Feb 10 2016, 06:13 PM
euro911   Dave is correct, the heads wouldn't require ma...   Feb 7 2016, 03:13 PM
Matty900   No rust just dirt   Feb 9 2016, 10:46 PM
Matty900   I have a Restoration Design battery tray and suppo...   Feb 9 2016, 10:51 PM
Matty900   Looking good.   Feb 9 2016, 10:53 PM
veekry9   [url=https://www.youtube.com/watch?v=3O-Ol2OmZx...   Feb 10 2016, 04:25 AM
Mikey914   Told him to try cleaning with simple green 1st. Th...   Feb 10 2016, 09:32 AM
Matty900   I was able to get a better look at the car today. ...   Feb 11 2016, 01:44 AM
Matty900   I am not sure what rust issues I may have inside t...   Feb 11 2016, 01:48 AM
Matty900   Took off the rocker pannels and there was lots of ...   Feb 11 2016, 01:51 AM
Matty900   What is the best way to take care of this level of...   Feb 11 2016, 10:14 PM
Matty900   Decided to go ahead and fix the damaged fender and...   Feb 18 2016, 12:57 AM
Matty900   Everything is coming apart nicely.   Feb 18 2016, 01:01 AM
Matty900   Getting ready to steam clean everything.   Feb 18 2016, 01:08 AM
Matty900   Very nice red breaks. I guess there was some lefto...   Feb 18 2016, 01:17 AM
Matty900   Steam cleaning today   Feb 18 2016, 04:51 PM
Matty900   Few more photos from today   Feb 18 2016, 10:47 PM
Krieger   Nice find! Add the Vin to our data base.   Feb 19 2016, 12:04 AM
Matty900   :Qarl: Hell hole fixed!   Mar 8 2016, 08:41 PM
Mikey914   :Qarl: Hell hole fixed! Get some paint shot ...   Mar 10 2016, 01:20 AM
cwpeden   Nice progress, looks like you have a mix of long ...   Mar 8 2016, 10:26 PM
Matty900   Coming and going. Got the 72 home to complete the ...   Mar 26 2016, 07:15 PM
Matty900   Have not had much time lately to post progress on ...   Apr 14 2016, 12:33 AM
Matty900   Driver's side fender had some issues after the...   Apr 14 2016, 12:39 AM
Matty900   Someone had drilled a few holes in behind the bump...   Apr 14 2016, 12:45 AM
Matty900   Dents are almost all pulled.   Apr 14 2016, 01:14 AM
Matty900   Put down some primer just to keep any rust from st...   Apr 14 2016, 01:16 AM
Jason74914   Just curious...what are the holes the rear trunk l...   Apr 14 2016, 10:22 AM
Matty900   Ok this car has been stalled too long. I have enli...   Jan 31 2017, 07:41 PM
Matty900   A few more of Kent's progress on my car   Jan 31 2017, 07:44 PM
pete000   Nice find ! Nice save !   Jan 31 2017, 11:04 PM
Matty900   Nice find ! Nice save ! Thank you, It i...   Feb 1 2017, 08:06 PM
Matty900   Haven't posted progress on here for a little b...   Mar 14 2017, 11:19 PM
Matty900   Next was laying color down in the trunks   Mar 14 2017, 11:25 PM
Matty900   Finally Color   Mar 15 2017, 12:04 AM
Matty900   More photos   Mar 15 2017, 12:07 AM
Matty900   Engine bay is all good to go.   Mar 15 2017, 12:10 AM
Matty900   and lots and lots of cutting and buffing (over 25 ...   Mar 15 2017, 12:15 AM
Matty900   :shades2:   Mar 15 2017, 12:16 AM
Matty900   :Qarl:   Mar 15 2017, 12:18 AM
Matty900   Raptor floor boards (14 hours)   Mar 15 2017, 12:21 AM
Matty900   Undercoated the complete car with rubberized under...   Mar 15 2017, 12:24 AM
Matty900   My rear valance was a little too far gone. PO took...   Mar 15 2017, 01:05 AM
Matty900   Cary Kutter freshened up some of the suspension fo...   Mar 15 2017, 01:20 AM
Cairo94507   Very cool and exciting. :beer2:   Mar 15 2017, 06:37 AM
RobW   Great color! Keep up the good work! :head...   Mar 15 2017, 12:13 PM
cary   What was the black stuff they sprayed in the trunk...   Mar 15 2017, 10:05 PM
Matty900   What was the black stuff they sprayed in the trun...   Mar 16 2017, 12:56 AM
cary   What was the black stuff they sprayed in the tru...   Mar 16 2017, 08:04 AM
Matty900   Tank looks like new. Now I just need to coordinate...   Mar 16 2017, 12:59 AM
Matty900   Some updates Cary Kutter cam out to the body shop ...   Mar 24 2017, 12:59 AM
Matty900   Rebuilding the peddle cluster and replacing everyt...   Mar 24 2017, 01:06 AM
Matty900   A few nights a week to get work done, but a lift, ...   Mar 24 2017, 01:09 AM
Matty900   The car is in great shape and all of the nuts and ...   Mar 24 2017, 01:14 AM
Matty900   Pulled the factory fuel lines to replace them with...   Mar 24 2017, 01:23 AM
Matty900   Engine bay ready for some love. Rubberized underco...   Mar 24 2017, 01:29 AM
Matty900   Haven't updated for a little while so here...   Apr 18 2017, 06:40 PM
Matty900   With the suspension out. We will freshen everythin...   Apr 18 2017, 06:51 PM
Matty900   Some cleaning needed   Apr 18 2017, 06:55 PM
Matty900   Blasting work   Apr 18 2017, 07:08 PM
Matty900   Some parts ready for powder coating   Apr 18 2017, 07:11 PM
7 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 19th April 2025 - 03:53 PM
