Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Like the title says. I've been looking at making the speaker pods, but this is a big project. To even think about starting I would need to do at least 100 sets. The tooling is quite expensive, and I'm not sure there's enough demand to support it. In all honesty 200 sets may cover the tooling, but unless there is a big enough demand this could be a dead end project.
Your thoughts? |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,341 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
I think a 5x7 would fit flush if the mounting nuts were moved to the far corners. Right now they are in the way of even a normal 4x6. Changing the housing might not be needed.
You also have the height issue on the drivers side with the trunk release, so 5x7 might be too tall anyways. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
I think a 5x7 would fit flush if the mounting nuts were moved to the far corners. Right now they are in the way of even a normal 4x6. Changing the housing might not be needed. You also have the height issue on the drivers side with the trunk release, so 5x7 might be too tall anyways. Good replys here for Mark I think the price thing is sorted eh,the remake to modern speakers is the only way to go but there are real issues with magnet size...most are large,go smaller and there is a less gain over stock size. Should Mark or others suggest a 5 x 7'' that would do the job?,I don't know as I'am sans heater and have fiberglass ones for for Blaupunkt 6''. Imo the show guys would be a small part of sales so really a mod to larger speakers is the way to go. Can Mark "tool up"(ha ha) for less numbers and make a run for the higher price..don't know. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:34 AM |
