How do I remove this?, Engine shroud help |
jack20 |
Feb 24 2016, 01:00 AM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
With the help of the engine removal thread (thanks for all the useful text and photos),
I dropped my 2.0 on Sunday, the DAPO painted the alloy fan should black. Now the DACO, me, is trying to remove the shroud so I can have it media blasted back to natural. The front half seems to be hung up in the alternator area but I can't find any more screws or bolts to remove. The inner is still solid to the engine. I need to get these off. Photo is not of my engine but the alloy shroud is what I'm trying to remove. Any suggestions? |
jack20 |
Feb 24 2016, 11:46 AM
Thank you.
Yes I removed the alternator leads. I do have a Haynes manual. This is uncharteted territory for me and frankly I get a little cautious on some of this stuff. Probably more than I should. Seeing the engine disembodied from the car for the first time, in my own garage is intimidating. I'm taking notes and pictures as I go. This project is simply to refresh the tins, engine bay, fuel lines, brake lines, suspension and brakes. Thanks again for the help. |
BeatNavy |
Feb 24 2016, 11:49 AM
Certified Professional Scapegoat Group: Members Posts: 2,933 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Thank you. Yes I removed the alternator leads. I do have a Haynes manual. This is uncharteted territory for me and frankly I get a little cautious on some of this stuff. Probably more than I should. Seeing the engine disembodied from the car for the first time, in my own garage is intimidating. I'm taking notes and pictures as I go. This project is simply to refresh the tins, engine bay, fuel lines, brake lines, suspension and brakes. Thanks again for the help. But did you remove the BOOT as Shane asked? That's the rubber part that can be seen in 911Buff's picture above (it's around the 3 o'clock position). It funnels cooling air over the alternator. You may just need to gently press it through the opening if that's what is causing the shroud to hang. |
Lo-Fi Version | Time is now: 21st September 2024 - 06:49 PM |
