Oil Leak Hell |
Oil Leak Hell |
orbit398 |
Feb 26 2016, 07:00 PM
Member Group: Members Posts: 139 Joined: 29-April 15 From: League city, Texas Member No.: 18,681 Region Association: Southwest Region |
I like to ideas on what the heck is going on.
Doing a 1974 914 restoration. Stripped completely down to just the chassis, painted etc..... Ran great prior to start but had an oil lead that dripped down from the oil pump pressure relief valve screw. Assume it was the oil radiator. While engine was out, I replaced seals that mate the oil radiator to motor, making sure new seals were siliconed in place so they could not move during re-installation. Welded a nut to the oil pressure relief valve screw so I could really tighten it good (with new seal). Thought I fixed the oil leak. Installed engine, hooked up, started up. Still leaks oil staight down to Oil Pressure Relief Valve. Assume it can only be the stupid oil radiator again. What else could it be? Leaks good when engine running. Any ideas? thanks |
TheCabinetmaker |
Feb 27 2016, 06:15 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The oil filter console is just above the relief valve. A leak there will end up on the valve.
Btw, throw that silicone in the trash. It, or rtv, has no business anywhere on a 914 engine. One little glob will stop up oil passages and destroy the engine. |
orbit398 |
Feb 27 2016, 11:04 AM
The oil filter console is just above the relief valve. A leak there will end up on the valve. Btw, throw that silicone in the trash. It, or rtv, has no business anywhere on a 914 engine. One little glob will stop up oil passages and destroy the engine. Thanks for the suggestion, will investigate. From pics I have seen, assume the o-ring that is used at the 'oil filter console' could be the culprit? Can it be changed out via under the car? ONLY a tiny amount of silicone was used to position those new gaskets- dried in place over night, then mated oil cooler so nothing introduced in to oil loop. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:52 AM |
