era vulgaris |
J is for Genius ![]() ![]() ![]() Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States ![]() |
This is a continuation from another thread, but to summarize my car very suddenly started driving like crap yesterday. In the middle of a drive it started popping and sputtering, and became pretty much undriveable. AFR was suddenly in the high teens.
At first I thought it was to do with fuel delivery. That turned out not to be the case. What I noticed today after I managed to get it to actually idle is that during warm up, cylinders 1 and 2 seem to be acting normal. But 3 and 4 heat up extremely quickly, and heat up past their normal idle temps and would probably continue to heat up well into the danger zone if I let them. I'm running DRLA 40's, and I'm still getting to know these carbs. The idle jets are clean. All I can think is that there's possibly a vacuum leak, maybe a seal or gasket failed suddenly while I was driving. They were rebuilt about 5 years ago though. Time for a rebuild? Anyone who knows Dells well know of anything I should check before I start tearing them apart? And does the rebuild kit from CB include everything I'll need? |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Swap the carbs around 180*. Carbs and linkage intact leaving the intakes in place. Your linkage will now be on the other side. If the problem doesn't follow the carb it's something else. 8 nuts and washers. Is the carb in ? Snapping back thru the carb and exhaust?
Lo-Fi Version | Time is now: 26th June 2024 - 12:19 PM |
