Tryin to fit a Mallory Unilite, These things are sure big |
DNHunt |
Oct 2 2004, 05:37 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
And they point the wrong direction.
First you have to beat on the tin so the dizzy cap will fit. Then you have to index the dizzy drive shaft cause the rotor points at I don't know what. The vacuum cannister interferes with the oil filler tube. Kind of a mess Attached image(s) |
DNHunt |
Oct 2 2004, 07:46 PM
I did it because I just plain couldn't get it to rotate enough to be able to time it. Believe me I didn't want to index it since this is short term until I get a fueling map and some hint of an advance curve. Then, I'm changing to a crankfire programmable ignition and I'll sell this. I just didn't have enough confidence to try to tune a new fuel injection map and ignition map together.
After I get rid of the dizzy I'm gonna run a dummy and keep the dizzy drive indexed to the stock position. Someday I hope to include a cam position sensor so I can run coil on plug and possibly sequential injection. Dave |
Lo-Fi Version | Time is now: 26th June 2024 - 06:07 AM |
