DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
And they point the wrong direction.
First you have to beat on the tin so the dizzy cap will fit. Then you have to index the dizzy drive shaft cause the rotor points at I don't know what. The vacuum cannister interferes with the oil filler tube. Kind of a mess Attached image(s) ![]() |
Tom Perso |
Crazy from the Cold... ![]() ![]() ![]() Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 ![]() |
QUOTE(cgnj @ Oct 2 2004, 04:20 PM) If you use stock wires, you'll end up with a short one. Carlos Hmm, good point. I've run all aftermarket wires and haven't had a problem (yet). But, I could see that with a stock set. Later, Tom |
Lo-Fi Version | Time is now: 26th June 2024 - 05:56 AM |
