cooper951 |
Member ![]() ![]() Group: Members Posts: 83 Joined: 30-September 15 From: Central Missouri Member No.: 19,219 Region Association: None ![]() |
I've had recurring issues with the hot start problem. I had the starter rebuilt with a new solenoid, and I installed the Bosch hot start relay. So far so good. But is there a way to start the car if it happens to me 50 miles from home besides push start? I tried jumping the battery connection on the solenoid to the starter with the ignition "ON" and I could hear the starter "whrrr" but it never engaged into the flywheel. TIA
cooper951 |
So you put the bosch relay in and you're still have a hot start issue? (IMG:style_emoticons/default/idea.gif) I'd almost give you the money to try a Ford solenoid. But, then if you are shorting the starter correctly it should engage. Does it whir or just click when you have the issue? Grounds are always the first thing you check. Not having the problem since installing the relay. Just looking down the road...so to speak. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:48 AM |
