hot start issue, is there a fall back way to start? |
cooper951 |
Mar 21 2016, 07:34 AM
Member Group: Members Posts: 83 Joined: 30-September 15 From: Central Missouri Member No.: 19,219 Region Association: None |
I've had recurring issues with the hot start problem. I had the starter rebuilt with a new solenoid, and I installed the Bosch hot start relay. So far so good. But is there a way to start the car if it happens to me 50 miles from home besides push start? I tried jumping the battery connection on the solenoid to the starter with the ignition "ON" and I could hear the starter "whrrr" but it never engaged into the flywheel. TIA
jimkelly |
Mar 21 2016, 11:28 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i thought hot start had to due with hot gasoline and fuel pump being in engine bay.
that aside, i put a bosch relay near my starter, one problem i have is from driving in bad weather, is corrosion on the terminals. i've installed a wire from battery to a momentary switch and the end terminal is near starter, and when my car won't start, i pull the ignition wire to starter and install the wire from my half assed momentary switch and it starts fine. meaning the starter turned engine and car starts. i should wire this switch to my dash as an always available back up. when my wires are wet and corroded, starter does not turn at all. i hate rainy salty days : ( Attached image(s) |
ClayPerrine |
Mar 21 2016, 11:55 AM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
i thought hot start had to due with hot gasoline and fuel pump being in engine bay. that aside, i put a bosch relay near my starter, one problem i have is from driving in bad weather, is corrosion on the terminals. i've installed a wire from battery to a momentary switch and the end terminal is near starter, and when my car won't start, i pull the ignition wire to starter and install the wire from my half assed momentary switch and it starts fine. meaning the starter turned engine and car starts. i should wire this switch to my dash as an always available back up. when my wires are wet and corroded, starter does not turn at all. i hate rainy salty days : ( All you have to do to get the engine to crank is to hook a wire from the battery to one of the rear two pins on the 4 pin connector that is located on the right rear of the relay board. Both those connectors go straight to the starter solenoid. |
Lo-Fi Version | Time is now: 25th September 2024 - 10:44 PM |
