> 1970 Turn Signal Relay
podiummotorsports
post Mar 23 2016, 12:29 PM
I am wondering if anybody knows if the early 914 has a turn signal relay. The only reason I ask is because when I use the right turn signal and press on the brake I get both flashers flashing but when I use the left turn signal and press the brake it works fine. After reading many post people suggested cleaning the ground (done) and replace the turn signal relay. Here is a pic of my fuse box/ relays. It doesn't look like any of the others I have seen people post. Since this is a 1970 914 I was wondering if it was located somewhere else or if they didn't use them and I need to keep researching.
jcd914
post Mar 23 2016, 01:10 PM
The flasher relay is square with 4 wires to it.
It is not attached to the fuse panel but under the dash near by.
Jim
podiummotorsports
post Mar 23 2016, 02:54 PM
Thanks Jim. Found it and finally got it out. Now going to track down a replacement. Thanks for your help.
QUOTE(jcd914 @ Mar 23 2016, 12:10 PM) *
Jim
podiummotorsports   1970 Turn Signal Relay   Mar 23 2016, 12:29 PM
jcd914   The flasher relay is square with 4 wires to it. It...   Mar 23 2016, 01:10 PM
podiummotorsports   Thanks Jim. Found it and finally got it out. Now...   Mar 23 2016, 02:54 PM
porsche913b_sp   Can I ask you how the square silver relay on the f...   Mar 23 2016, 07:06 PM
porsche913b_sp   FYI if you can't find a replacement. I wasn...   Mar 23 2016, 07:17 PM
eitnurg   Just be aware that for everything to function pr...   Mar 24 2016, 01:39 AM
podiummotorsports   porsche913b_sp I will send a pic of the bottom whe...   Mar 24 2016, 04:32 PM
porsche913b_sp   If you can take a pic of the part number of that r...   Mar 24 2016, 05:25 PM
podiummotorsports   Sorry for the delay in getting the pics and detail...   Mar 26 2016, 07:34 AM
mepstein   Sorry for the delay in getting the pics and detai...   Mar 26 2016, 11:44 AM
Mikey914   Sorry for the delay in getting the pics and detai...   Mar 29 2017, 09:20 PM
porsche913b_sp   Thanks Aaron for pics ! :beer2: :driving:   Mar 26 2016, 11:10 AM
Strudelwagon   who was the local supplier of the GOOD one?   Apr 4 2016, 05:08 PM
podiummotorsports   In southern california these guys are located in H...   Apr 5 2016, 08:34 AM
ChristopherB   I am trying to replace my turn signal relay. I ha...   Jul 31 2016, 10:48 AM
ChristopherB   Here is a picture of my fuse panel dropped. I was...   Jul 31 2016, 10:51 AM
ChristopherB   Found it. Hard to wiggle out of its connector, bu...   Jul 31 2016, 02:16 PM
914Sixer   Large and small silver (metal) at the right end is...   Aug 1 2016, 05:49 AM
ChristopherB   I got in the car today delighted that everything i...   Aug 2 2016, 03:34 PM
Mike Bellis   RIch Bontempi at High Performance House in Redwood...   Aug 2 2016, 06:48 PM
Spoke   It sounds like your flasher is pulling in the 4 th...   Aug 3 2016, 04:55 PM
ChristopherB   The turn signal indicators on the dash are gently ...   Mar 29 2017, 07:12 PM
Spoke   The turn signal indicators on the dash are gently...   Mar 30 2017, 06:40 AM
eitnurg   The turn signal indicators on the dash are gently...   Mar 30 2017, 11:23 AM
ChristopherB   Thanks!   Mar 30 2017, 02:12 PM
- Lo-Fi Version Time is now: 14th January 2025 - 05:57 AM
