1970 Turn Signal Relay |
podiummotorsports |
Mar 23 2016, 12:29 PM
Newbie Group: Members Posts: 39 Joined: 7-October 12 From: Rossmoor, CA Member No.: 15,011 Region Association: Southern California |
I am wondering if anybody knows if the early 914 has a turn signal relay. The only reason I ask is because when I use the right turn signal and press on the brake I get both flashers flashing but when I use the left turn signal and press the brake it works fine. After reading many post people suggested cleaning the ground (done) and replace the turn signal relay. Here is a pic of my fuse box/ relays. It doesn't look like any of the others I have seen people post. Since this is a 1970 914 I was wondering if it was located somewhere else or if they didn't use them and I need to keep researching.
Attached thumbnail(s) |
913B |
Mar 23 2016, 07:06 PM
Senior Member Group: Members Posts: 855 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Can I ask you how the square silver relay on the far right is attached to relay board. Apparently mines is not attached in anyway, is there like a clip on the top of the relay that clips to the board or something ??
Thanks. |
Lo-Fi Version | Time is now: 14th January 2025 - 05:57 AM |
