> Fuel gauge conversion from oil pressure guage?
Eddie914
post Oct 3 2004, 10:59 PM
Unregistered
I don't have a fuel gauge since it was replaced with a combo oil pressure/temp gauge for the 2.7 6 cylinder.
I have heard that an oil pressure gauge can be converted for use as a fuel guage. Geoff told me that there is a thread that describes the conversion. I have tried looking at the classic threads and performing a search, but have had no luck.
Can anybody help me?
Eddie
lapuwali
post Oct 4 2004, 09:33 AM
Not another one!
I think the idea is he wants to keep the combo gauge as is, and add a fuel gauge to the center console, using the 914 oil pressure gauge housing.
The chief problem is finding that particular VDO gauge (the 3309556). None of the usual suspects carries it, and it's the only one that handles the resistance range of the 914 tank sender (which, btw, is exactly the same as the 911 tank sender, and not the same as any VW sender). If anyone knows of a place that stocks that part, I'd like to know about it.
I've seen at least one thread (perhaps it was on the Bird Board) that discussed gutting the oil pressure gauge and fitting the guts of the stock fuel gauge into it, making their own face. Seems fiddly. PA Speedo or North Hollywood Speedo can also do this for you, for something in the $100 range, I believe.
I also have the 911 temp/press combo gauge, but I don't have a center console. My solution at present is to use the trip odo, and I hooked the wiring for the fuel level light switch to the oil pressure light on the combo gauge, so I get at least SOME indication of low fuel.
Eddie914   Fuel gauge conversion from oil pressure guage?   Oct 3 2004, 10:59 PM
ChrisReale   I dont want to change the subject, but I have a 93...   Oct 3 2004, 11:38 PM
Dr Evil   If it is the 911 style dual side gauge like the on...   Oct 4 2004, 12:33 AM
Dr Evil   Here is the 911 gauge   Oct 4 2004, 12:37 AM
Dr Evil   Optional VDO #3309556   Oct 4 2004, 12:39 AM
lapuwali   I think the idea is he wants to keep the combo gau...   Oct 4 2004, 09:33 AM
914forme   Why not run a triple gauge, I made up a bunch a wh...   Oct 4 2004, 09:46 AM
Bleyseng   I did the conversion of a stock oil TEMP center co...   Oct 4 2004, 10:00 AM
Dr Evil   Lapuwali, they are at the place that you mentioned...   Oct 4 2004, 10:10 AM
Root_Werks   <...   Oct 4 2004, 10:15 AM
Aaron Cox   make more!!!! and make em cheap...   Oct 4 2004, 10:23 AM
Root_Werks     Oct 4 2004, 10:32 AM
Bleyseng   I find the triple gauge to busy as all the gauges ...   Oct 4 2004, 10:57 AM
Dr Evil   Ok Geoff, You want a larger one? Here is a 2 5/8" ...   Oct 4 2004, 11:12 AM
Bleyseng   As it notes its discontinued and I couldn't ob...   Oct 4 2004, 11:29 AM
Eddie914   Geoff, Thanks! That's the idea I now reme...   Oct 4 2004, 12:17 PM
lapuwali   Evil, I know about egauges, I've ordered a bun...   Oct 4 2004, 12:23 PM
Dr Evil   301-601 is the second one downa dn is not disconti...   Oct 4 2004, 12:29 PM
lapuwali   The VDO float type "universal" sender is 10-180ohm...   Oct 4 2004, 01:05 PM
Dr Evil   Lapuwali, according to both the people at NH speed...   Oct 4 2004, 02:16 PM
lapuwali   I got my numbers by hooking a DMM up to a fuel sen...   Oct 4 2004, 03:06 PM
Dr Evil   James, I didn't get a notice that you replied...   Oct 25 2004, 08:26 PM
Dr Evil   Here is an option if the stock sender is not 10-18...   Oct 25 2004, 08:38 PM
lapuwali   Just buying that gauge would probably be expensive...   Oct 25 2004, 09:39 PM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 4th February 2025 - 02:58 PM
