Amphicar770 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,199 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region ![]() ![]() |
I was looking into proper grease for throw out bearing and shaft. Came across this grease from Honda, made just for such applications. Figured I would share.
Genuine Honda 08798-9002 Urea Grease https://www.amazon.com/dp/B00BFDFYKW/ref=cm...d_7aebxb18R79J6 |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I was looking into proper grease for throw out bearing and shaft. Came across this grease from Honda, made just for such applications. Figured I would share. Genuine Honda 08798-9002 Urea Grease https://www.amazon.com/dp/B00BFDFYKW/ref=cm...d_7aebxb18R79J6 Urea is the component of pee....not shitting you...urea urine. Most grease uses soap as part of the base, Swepco 101 is lithium base. this is urea base. Soap based grease flow at lower temps, the lithium or urea is higher temp. BTW never thought about a urea grease, but I did now the urea is used heavily in cosmetics. Kiss a girl with lots of make-up on and you are kissing pee. (IMG:style_emoticons/default/happy11.gif) |
6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
I was looking into proper grease for throw out bearing and shaft. Came across this grease from Honda, made just for such applications. Figured I would share. Genuine Honda 08798-9002 Urea Grease https://www.amazon.com/dp/B00BFDFYKW/ref=cm...d_7aebxb18R79J6 Urea is the component of pee....not shitting you...urea urine. Most grease uses soap as part of the base, Swepco 101 is lithium base. this is urea base. Soap based grease flow at lower temps, the lithium or urea is higher temp. BTW never thought about a urea grease, but I did now the urea is used heavily in cosmetics. Kiss a girl with lots of make-up on and you are kissing pee. (IMG:style_emoticons/default/happy11.gif) Polyurea.. (IMG:style_emoticons/default/lol-2.gif) theres only a capitil P in it |
Lo-Fi Version | Time is now: 26th June 2024 - 10:40 AM |
