Carb rebuild help, looking for carb rebuild kit |
mobymutt |
Apr 9 2016, 03:00 PM
Senior Member Group: Members Posts: 553 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
I guess before I buy a rebuild kit, I need to know what carbs I have. Can anybody positively identify these, or let me know how I go about identifying them?
I have been assuming they are Weber 40's. If that is the case, will this kit work? https://www.cip1.ca/ProductDetails.asp?Prod...de=ACC-C10-5542 Would I need anything else on top of what is supplied in the kit? |
ThePaintedMan |
Apr 9 2016, 06:23 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
I've seen it stamped there once before, perhaps I was wrong. If you're rebuilding them, why not go ahead an pull them off and have a closer look? If still no stampings are visible, measure the the diameter of the bottom of the throats.
FYI, most Weber 36, 40 and 44 kits should include all gaskets, regardless of carb size. You order them and select the right top gasket once you get the kit in front of you. |
Lo-Fi Version | Time is now: 26th September 2024 - 12:06 PM |
