JDW914 |
Newbie ![]() Group: Members Posts: 25 Joined: 27-April 11 From: Toledo, Ohio Member No.: 12,990 Region Association: Upper MidWest ![]() |
I'm not sure what's going on here, but I'm hoping somebody here will.
I've been driving my car ('74 2.0 all original engine and FI) for a few years now, I did some tuning last summer, and it's been running great since. But, having it out only once a week at most, this winter the battery had started to show signs of wearing out - the car was getting hard to start and often needed charging - so last week I bought a new battery and installed it. Initially, this seemed to work great: I turned the key, the car started immediately, and it idled perfectly at 1200rpm. However, as soon as I touched the gas, the engine revved to 3000 and stayed there for about 20 seconds. Upon experimentation, it seemed that the engine would retain both power and speed of any throttle position for a ~20s period after the throttle was returned to idle. I was able to alleviate this to some extent by turning the idle-mixture adjustment to maximum and opening the idle bypass by 5 turns, but it still acts weird. When I set the idle mixture to do anything besides flood the rpm down, the engine stays at 1500 rpm even with the idle bypass closed all the way and the AAV closed off. My instinct is that it's a vacuum leak, but there's not a whistle to be hard or lose hose to be seen. Could it be (I hope not) something to do with the FI system? |
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
From High School shop 55 years ago. .
Always disconnect the ground first and connect the ground last. . The reason being if you disconnect the hot / positive and your wrench accidentally touches the body of the car or other metal you will have a giant arc flash and probably burn yourself. . same goes for having on a metal ring on a finger, potential of a shock / burn also. . with the ground disconnected first, touching the positive terminal can make a complete circuit because there is no path for the negative terminal, {unless you drop a wrench across the terminals] |
era vulgaris |
J is for Genius ![]() ![]() ![]() Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States ![]() |
From High School shop 55 years ago. . Always disconnect the ground first and connect the ground last. . The reason being if you disconnect the hot / positive and your wrench accidentally touches the body of the car or other metal you will have a giant arc flash and probably burn yourself. . same goes for having on a metal ring on a finger, potential of a shock / burn also. . with the ground disconnected first, touching the positive terminal can't make a complete circuit because there is no path for the negative terminal, {unless you drop a wrench across the terminals] (IMG:style_emoticons/default/agree.gif) Disconnecting the positive terminal first is dangerous. |
Lo-Fi Version | Time is now: 26th June 2024 - 05:48 AM |
