naro914 |
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States ![]() |
**NOTE: on 3/20 I changed the title of this post because at first I just had a question (this post)...but now I am sharing my experience regarding replacing your 914 suspension with Koni Adjustable shocks because a lot of people asked or seemed interested. Jump to Post 13 for "The rest of the story"....
_________________________________________________________ It's been a while since I've posted a stupid question - heck I've been so busy lately and not done much with my 914's in months that its been a while since I've posted ANYTHING at all... (Papa Smurf is away at Dawe's Motorsports winter camp spending all our retirement savings and Huey has been sitting patiently in the garage waiting for nice weather...) So here's my dilemma: I ordered a full set of Koni Sport adjustable shocks for Huey, and I got the coil-over set up from Ground Control for the rear. They came Friday, and I was excited to get working on them Sunday (was busy Saturday). ![]() So...after doing a bunch of things to our other cars that needed the lift, I got Huey up there, took off one of the rear Bilsteins (figured I'd start on the easy end first, easy remove and install right?) and looked at what I had in the new box, and what I had on the old shock. I realized I needed basically all the hardware that goes above the spring hat (washer, threaded collar (Porsche calls it a bushing) and rubber bushing) that was below the hole, and the bushing and washer above. Basically everything above the hat except the top nut (which they give as a lock nut). This is where the stupid question comes in: Are there different threaded collars (bushings) for Bilstein and Koni? Look at these pictures: First one is the threaded collar, screwed all the way down on the Bilstein as it's supposed to - and the rubber bushing goes over it. The second one is as far as the collar will go...which is not at all because the thread pitch on the Koni is different!! Do I need a special threaded collar for Konis? Did they not send me something I should have? Suspension is something I've honestly never messed with... ![]() ![]() I'm going to call Ground Control later today, but thought I would throw this out there to the World braintrust and see what responses I get since I'm SURE some of you have upgraded to Koni adjustables... Thanks! |
Paragon |
Newbie ![]() Group: Members Posts: 49 Joined: 6-February 03 From: Corpus Christi, Texas Member No.: 255 Region Association: Southwest Region ![]() |
The Koni 8641-1077 Sport insert for the front 914 strut will work on Boge struts but not Koni housings. If you have Koni housings you'll need the 911 insert 8641-1039 Sport and this gland nut:
http://www.paragon-products.com/Koni-Gland...25.01.011.1.htm The 911 insert is shaped a bit differently and will drop right in the Koni housing. We do this stuff all the time. |
Gearup |
Member ![]() ![]() Group: Members Posts: 158 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None ![]() |
The Koni 8641-1077 Sport insert for the front 914 strut will work on Boge struts but not Koni housings. If you have Koni housings you'll need the 911 insert 8641-1039 Sport and this gland nut: http://www.paragon-products.com/Koni-Gland...25.01.011.1.htm The 911 insert is shaped a bit differently and will drop right in the Koni housing. We do this stuff all the time. Ok, so I was just about to purchase the Ground control setup for the rears with bilstein shocks. GC has told me to go with 10 inch springs. I want to make sure I am able to lower my GT to the ride heights I commonly see pictured on this website. Can someone please confirm that for the bilsteins the 10 inch springs are the way to go? Thank You, Brett |
Lo-Fi Version | Time is now: 30th June 2024 - 11:59 PM |
