jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
ARG! Working on someones side shifter, replacing old bushings. Or trying to. When I went to back out the conical screw on the forward most coupling knuckle, the damned allen screw rounded out. NOW how do I get the sucker out? An easy out? If I just try to drill it, I do not think I can get in far enough to get the cone portion out. HELP!
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
ARG! Working on someones side shifter, replacing old bushings. Or trying to. When I went to back out the conical screw on the forward most coupling knuckle, the damned allen screw rounded out. NOW how do I get the sucker out? An easy out? If I just try to drill it, I do not think I can get in far enough to get the cone portion out. HELP! I did that once too. You can try over size, tack something on there. Is there any part of the cone screw sticking out and over that you can get a vice grip on? The screw can get tight on installation if not lined up right. I ended up drilling out mine and needing a whole new connector rod. I may have one if you want to come by.... not sure about a spare mirror... |
jeffdon |
ARG! Working on someones side shifter, replacing old bushings. Or trying to. When I went to back out the conical screw on the forward most coupling knuckle, the damned allen screw rounded out. NOW how do I get the sucker out? An easy out? If I just try to drill it, I do not think I can get in far enough to get the cone portion out. HELP! I did that once too. You can try over size, tack something on there. Is there any part of the cone screw sticking out and over that you can get a vice grip on? The screw can get tight on installation if not lined up right. I ended up drilling out mine and needing a whole new connector rod. I may have one if you want to come by.... not sure about a spare mirror... Eeesh. I will try to force an oversize allen into it. Maybe some heat too to unstick things. |
tomrev |
Member ![]() ![]() Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None ![]() |
Probably you know, but careful with the heat, so the bushings don't melt. I have better luck with a 3/8ths drive allen, as I can start the next size up, and hammer it in, and the hammer banging will loosen the threads. If not, drill a little bit thru, and hammer on the smallest easy out to get her out. A lot of fuching around for a simple move, I know!
Lo-Fi Version | Time is now: 26th June 2024 - 06:35 AM |
