914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Okay a recent post got people interested in this item once again. So since I did part of the orginal kit, I thought I would offer up to do them again.
Price I am not sure yet, shooting for below $100 shipped, will try to make it less than that. So here you go what all is in the kit and what is not. Backing plate, silver cadium plated, laser cut so acuracy is with in 0.0001" not bad. My plater does this stuff plating for a lot of space and aviation industry people. Front Plate - CNC milled to get the bevel into the face. Powder coated, then the faces are silk screened. I make them with out the hole drilled for the silver button, I provide a template for use if you want to drill it. Or I may just have a batch made with some holes and some with out. The face will then be screened with the gauge names onto it. It will have a gound spade lug, instructions, and great care and packing. So if you have interest let me know I will start the ball rolling, which I have already done, I have the Machinist, platter and powder-coater all lined up. So what am I missing?????? A silk-screener - I need a excellent silk screener, recommendations are allowed, needs to be high quality, and professional. Okay if you are interested I will start a list here, this will be a 914 club exclusive. But once they are gone, I will do this only this time. Twice is a too much. So let me know your interest and if you want the center dot cut out or make it a flat panel. Pictures to follow latter tonight once I get some new ones. Thanks, Stephen |
cgnj |
Senior Member ![]() ![]() ![]() Group: Members Posts: 627 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None ![]() ![]() |
QUOTE I built one of the old kits, if you reduce the OD of the face plate it will fit inside the donor face plate. That way, after you nibble away the old you will be left with a ring with the tabs still attached. This makes it much easier to mount the new face plate. Thats the answer. Carlos |
