orthobiz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,755 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest ![]() ![]() |
Update: No new engine for me right now, the 1.8 is once again running strong. Thanks everybody for looking at my videos and posting in this thread.
Paul Edit: I added some video of my 1.8 engine's behavior. What you are seeing is about 2 minutes into the engine running from a cold start. I tried to capture a little of the shakiness of the engine as well. Wondering if anybody has a good idea of what's going on as I may want to sell the engine after the swap. 914 1.8 Stalling Original Post: So late last "season" (Porsche weather is May to November here in Michigan), my car stalled between shifts. Started up OK but conked out when warm. So...I discovered a disconnected hose and started a hose renewal project. After replacing every hose, the problem persisted. But along the way I had to replace the AFM as the car backfired and warped the flapping door. Still no success. Replaced the fuel injection seals, oil filler cap seals, still conks out after warm up. Contemplated a new brain and wiring harness and cylinder head temp sensor but have run out of patience. To make a long story short, I've decided to go with a 2.0 and plan on dropping my car off at Brad Mayeur's next weekend. I've always wanted more power anyway. Questions: 1. How much power am I losing by sticking with the stock 1974 exhaust system? 2. What to do with the 1.8? It ran strong before the problems developed, but the car is of unknown mileage. Seems like interest in these engines is, well, underwhelming. Brad said he has more than enough of these engines. 3. I'm sure he could get the 1.8 FI running on the 2.0, I know there are proponents of the L-Jet...Is that something worth pursuing or stick with the D-Jet? Thanks, Paul BTW, I have a pristine orange 1.8 that is staying stock. This is for my red driver! |
Rob-O |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region ![]() ![]() |
Just remembered something else. Did you check the seal in the oil cap filler? Maybe a new one might help. Yes. The red rubber seal was black and so hardened/brittle I had to cut it with tin snips. I replaced both seals. Every time I replaced a hose or the AFM rebuilt or injector seals I had hope it would run. I see there is love for the L-jet but I gotta tell you this vacuum sensitivity is making me nuts! Paul Where did you get the new red rubber seal??? I just posted earlier today that I am looking for one but having trouble finding a supplier that either carries them or has one in stock. |
Lo-Fi Version | Time is now: 26th June 2024 - 08:32 AM |
