GB Fuel line grommets 10mm and 8mm Correct "stopper" shape, Cary made me do it, well I needed them too $4 each |
Mikey914 |
Apr 28 2016, 12:44 AM
The rubber man Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Just finished the fuel line grommets for the fire wall area. Both are done, but I have a few other items that are done that I want to put up too so it may be a day or two as we wrap these up.
$4 a pop I'm going stainless on my lines and will do 10mm for both, but figures there would be those that wanted the correct ones for the OEM application. I have test fitted these on my Cary's car and they are a nice fit. The material is silicone so that it will make a great seal and are just slightly softer than the OEM to make them easier to install. So let me know who's up for some? Attached image(s) |
Mikey914 |
May 9 2016, 12:21 AM
Got these up on the site right here -
10mm http://shop.914rubber.com/Fuel-line-gromme...m?categoryId=-1 8mm http://shop.914rubber.com/Fuel-line-gromme...m?categoryId=-1 The original configuration calls for a 8mm and a 10mm grommet. The picture shows both grommets with a 10mm on the stainless line. Again only one 8mm grommet is included for this selection I did this as individual parts rather than a kit so if you were doing stainless lines and opted to do both in 10mm, you could simply order what you want. PM's going out to all who responded |
Lo-Fi Version | Time is now: 26th June 2024 - 09:45 AM |
