Rob-O |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region ![]() ![]() |
Changing back to FI, but a new Fuel Pressure regulator from Pelican. Installed it but didn't realize until this evening that the new regulator pressure is controlled by a bolt that is threaded through the center of the regulator, and a lock down nut holds the bolt in place. In other words, it is mechanically controlled, versus the pressure controlled regulator that I had.
Not sure if the new regulator is supposed to be that way (this part supersedes the old part) or if Pelican send me the wrong part. Just thought I'd throw the question out there tonight. Like an idiot I threw the box out so I don't know the part number of the new part. And wouldn't you know it, now that i've installed the part the part number is in an area that I can't see. No issues with pulling it out if needed. But thought the brain trust here may know off hand. |
Rob-O |
The vacuum line goes to the plenum. So if I understand The system correctly, the reg would pull vacuum when you hit the throttle. The vacuum produced would in turn pull the ball and spring and allow fuel to flow back to the tank (the regulators job). That would cause a drop in pressure in the fuel circuit because the regulator is the last item in the circuit. So if it opens, the pressure should drop. As I understand it via Clay Perrine, the FI is really only using ~28psi. That pressure is being built by the fuel pump. The regulator is there to allow excess fuel to be returned to the tank. You see 38 at idle because the fuel pump is producing this pressure, but there isn't enough vacuum being produced to open the regulator.
Ultimately the system is just trying to keep the fuel lines full. My assumption is that all five injectors would not be able to use enough fuel that it would drain the fuel lines faster than the fuel pump could replenish the line. |
Lo-Fi Version | Time is now: 28th June 2024 - 11:03 PM |
