Rob-O |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region ![]() ![]() |
Changing back to FI, but a new Fuel Pressure regulator from Pelican. Installed it but didn't realize until this evening that the new regulator pressure is controlled by a bolt that is threaded through the center of the regulator, and a lock down nut holds the bolt in place. In other words, it is mechanically controlled, versus the pressure controlled regulator that I had.
Not sure if the new regulator is supposed to be that way (this part supersedes the old part) or if Pelican send me the wrong part. Just thought I'd throw the question out there tonight. Like an idiot I threw the box out so I don't know the part number of the new part. And wouldn't you know it, now that i've installed the part the part number is in an area that I can't see. No issues with pulling it out if needed. But thought the brain trust here may know off hand. |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
Vacuum should be at its highest at idle, and lowest at WOT. The fuel pressure should be lowest at idle (high vacuum). At idle, the vacuum pulls up the diaphram which lifts the ball, essentially short circuiting the supply and return (#6 and #7).
As you lose vacuum (higher rpm), the diaphram moves down, which pushes the ball down to be seated. This closes the bypass (less fuel going back to tank) which will raise the fuel rail pressure. With the vacuum hose removed from the fuel regulator, you should see the highest pressure on the fuel rail. Adding vacuum to the fuel reg will decrease fuel pressure. |
pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
Vacuum should be at its highest at idle, and lowest at WOT. The fuel pressure should be lowest at idle (high vacuum). At idle, the vacuum pulls up the diaphram which lifts the ball, essentially short circuiting the supply and return (#6 and #7). As you lose vacuum (higher rpm), the diaphram moves down, which pushes the ball down to be seated. This closes the bypass (less fuel going back to tank) which will raise the fuel rail pressure. With the vacuum hose removed from the fuel regulator, you should see the highest pressure on the fuel rail. Adding vacuum to the fuel reg will decrease fuel pressure. This is exactly as I understand the system should function. I am just curious why mine drops when I crack open the TB which is opposite of what It should be doing...I will remote mount the gauge so I can see it while driving under load and see how it responds. Probably reads different under load conditions. |
Lo-Fi Version | Time is now: 28th June 2024 - 11:36 PM |
